Author Topic: A Triple Expansion Steam Engine in miniture  (Read 2815 times)
« on: November 01, 2019, 10:22:20 PM »
Gentlemen,
We have a video.
<a href="https://www.youtube.com/watch?v=KWF7jRd-3eU" target="_blank">http://www.youtube.com/watch?v=KWF7jRd-3eU</a>
Re: A Triple Expansion Steam Engine in miniture
« Reply #1 on: November 01, 2019, 11:22:34 PM »
Mighty fine, mighty fine!
Offline MJM460
« Reply #2 on: November 02, 2019, 01:14:05 AM »
Absolutely beautiful, George.  Great to see it running.
Now for a nice tug boat to install it in!
« Last Edit: November 02, 2019, 03:48:20 AM by MJM460 »
« Reply #3 on: November 02, 2019, 02:21:55 AM »
Just amazing George.  :ThumbsUp:
« Reply #4 on: November 02, 2019, 07:58:41 AM »
 8) Well done George,
I must get on and finish my three  :paranoia:
Offline ShopShoe
  • Central Iowa, Central USA
« Reply #5 on: November 02, 2019, 12:35:01 PM »
Well Done.
It was impressive, then I realized how small it is, which makes it even more-so.
Thank You for posting,
ShopShoe
Offline mike mott
  • Alberta Canada
« Reply #6 on: November 02, 2019, 12:58:11 PM »
Nice George, I had also thought that your engine was a lot bigger than it is. I am also surprised at how fast you built it.
Offline scc
  • Lancashire, UK
« Reply #7 on: November 02, 2019, 09:57:00 PM »
Excellent build!  the more so because of the size and the quick build. :praise2:               Terry
« Reply #8 on: November 02, 2019, 11:02:53 PM »
Nice job as usual.  Is the LP cylinder doing most of the work (assumed because it's larger).
« Reply #9 on: November 03, 2019, 12:09:19 AM »
If its plumbed as a compound, wouldn't the air have to get through the smallest one first, so there would be less to fill the big one? So the first, small cylinder, does all(most) the work? Or is this one plumbed for air, with intake from compressor to all three directly?   :headscratch:   Always wondered if a compound would really run decently on air, never tried one though.
Either way, wonderful engine!
« Reply #10 on: November 03, 2019, 11:50:38 AM »
The HP on air is making it go....the LP will probably over expand the air and create a vacuum, and is slowing it down so running with the LP drains open should make the engine go faster....unless the timing between cylinders has been changed to suite running on air.
« Reply #11 on: November 17, 2019, 06:51:54 AM »
Hi George, very well done. Seems to be designed for a high speed steam race boat.
Offline sbwhart
  • Live Long and Prosper
« Reply #12 on: November 17, 2019, 07:32:25 AM »
Smashing Job George  :cartwheel:
Stew
Offline Jeff Michel
« Reply #13 on: November 17, 2019, 10:44:59 AM »
Well done indeed. Thanks for sharing.
« Reply #14 on: November 17, 2019, 01:23:41 PM »
Just seeing the video George. Not only beautiful, but an amazing little runner as well. Most impressive!!!
