Author Topic: Machining cylinder barrel for Anzani Y type  (Read 1402 times)
Offline Trevorc
« on: October 27, 2019, 07:50:06 PM »
I am working to the L Chenery drawings to build the Anzani Y type. I am about to start the cylinder barrels. The build notes published in the ME specify the use of a 9/33 round nose counterbore with a 3/16 pin to produce the nicely curved inlet and outlet ports.
Enquiries have drawn a blank, friends have never heard of them and an extensive internet search has revealed nothing.
Are these tools still available, if so where to purchase?
Thanks for help
Trevorc
Re: Machining cylinder barrel for Anzani Y type
« Reply #1 on: October 27, 2019, 08:30:43 PM »
Probably one to make yourself, a 9/32 ball nose cutter drilled for a 3/16" guide pin to go into the valve guide hole
Could probably get away with a 9/32" or even 7mm ball nose milling cutter and let it just follow the 3/16" hole
You will never machine the curve as shown
« Last Edit: October 27, 2019, 08:48:16 PM by Jasonb »
« Reply #2 on: October 28, 2019, 08:27:47 AM »
You need to make yourself one out of silver steel. If you are using the original Aluminium castings then make the shaft of the cutter thicker as it is a long way down to the bottom of the cylinder.
The inner corner of the port will need to be filed or dremmeled to make it smooth.
Database Error
Back
