Author Topic: Part support while milling  (Read 2020 times)
Offline Paulc
« on: October 23, 2019, 03:14:43 AM »
What does one use to shim under a flat part when edge milling on a rotary rable?
Don't want to gouge the table inadvertently.
Re: Part support while milling
« Reply #1 on: October 23, 2019, 03:28:35 AM »
I use aluminum plate often times for a sacrificial shim.
Offline AOG
« Reply #2 on: October 23, 2019, 03:32:24 AM »
When I am feeling lazy I just clamp the part to a piece of aluminum waste stock to lift it off of the rotary table. When I’m feeling fancy I’ll make a sacrificial fixture out of aluminum or more recently 3D print one.
Tony
Online steamer
« Reply #3 on: October 23, 2019, 02:00:15 PM »
Many choices
I've used aluminum plate, and also  plywood!
If the cut is just cutting through, use the plywood as is.   If you have depth cuts that are important, mount the plywood up  first and face cut it with a fly cutter gently....that will bring it flat,    then mount the work piece down and have at it.
Clockmakers have used wooden chucks to machine all sorts of things for 500 years......
« Reply #4 on: October 23, 2019, 02:41:26 PM »
Whatever is to hand - Ply, MDF, Aluminium, Plastic sheet, etc Or pack with something that is smaller than the OD of the part so you don't cut it, subject to how it can be held.
Offline Paulc
« Reply #5 on: October 23, 2019, 10:59:40 PM »
 Thanks guys. All great ideas and I'm sure one or all will be tried depending what I have in the junk pile ;)
