Thanks Andy, when it first seized I was more than a little worried
Due to the type of water pump fitted to be able to get it to work it must be primed with water. On both the full sized engines and the models this is done by a Priming cup/tap on the side of the pump.
There are a few bits to this assembly that are simple turning tasks. The elbow has to be orientated the right way so the part that goes into the side of the pump was screwed in tight and the top marked on it before taking the two parts over to the mill to mill the 45 degree angle on them. These could then be silver soldered together.
The spindle through the tap was slotted for the handle, fitted through the tap body before drilling through the spindle so that the tap is orientated the right way when operated.
One more bit to make then a bit of plumbing, painting
and she will be done
