Author Topic: Flyboy Jim's PM Research #5  (Read 28816 times)
Re: Flyboy Jim's PM Research #5
« Reply #135 on: January 18, 2020, 03:22:04 AM »
Nice! Mandrels and arbors come in very handy, go great with the rotary table.   :popcorn:
Offline Flyboy Jim
  • Independence, Oregon
« Reply #136 on: January 18, 2020, 03:26:47 AM »
They sure do! I think before I'm done, it'll be modified to work like the one you did for the Steamer, so I can drill the steam ports.
Sherline 4400 Lathe
Sherline 5400 Mill
« Reply #137 on: January 18, 2020, 03:29:24 AM »
Lots of variants, caps, expanding arbors, side pins, depending on the part. Essential for gears too.
« Reply #138 on: January 18, 2020, 03:55:52 AM »
Great progress him. Still following along quietly.
« Reply #139 on: January 18, 2020, 11:18:41 AM »
Hello Jim,
It is taking shape very nicely and some really nice machining work  :ThumbsUp:
Have a great day,
Offline TerryWerm
« Reply #140 on: January 18, 2020, 06:00:16 PM »
You've made some great progress this week, Jim. It is good to see!
I agree that studs and nuts would look the best on the steam chest cover, and possibly on the head as well.
Terry
Making chips when I can!
Offline Flyboy Jim
« Reply #141 on: January 19, 2020, 03:08:25 AM »
Thanks guys. I'm gradually getting a little more time in the shop. Now that I'm walking again, things are progressing a little faster.  :cartwheel:
I turned the cylinder around on the arbor and worked on the other end. Drilled and tapped the mounting surface for the Valve Gland.
Drilled the mounting holes on this end. Have I mentioned that I love my Rotary Table?  :)
Got started working on the Valve Gland.
Sherline 4400 Lathe
Sherline 5400 Mill
« Reply #142 on: January 19, 2020, 03:12:06 AM »
I'd say that you are having too much fun, but it looks like the right amount!   :ThumbsUp:
Offline Flyboy Jim
« Reply #143 on: January 20, 2020, 03:10:43 AM »
Turned a piece of bar stock to the correct starting dimensions for the Valve Gland.
After drilling the hole for the shaft I moved the chuck over to the RT on the mill and drilled the mounting holes.
Then milled the Valve Gland the proper profile.
Moved the chuck back to the lathe and parted off. Reversed it in the chuck and faced it to the proper thickness. If I'd known how nice the groover was going to part it off, I'd of done it to the correct thickness and saved a step.  :(
Sherline 4400 Lathe
Sherline 5400 Mill
« Reply #144 on: January 20, 2020, 03:37:26 AM »
Quick progress lately, great parts!
Offline Flyboy Jim
« Reply #145 on: January 20, 2020, 03:58:51 AM »
It was nice to make something out of bar stock.  :)
Sherline 4400 Lathe
Sherline 5400 Mill
Offline propforward
  • MN, USA
« Reply #146 on: January 20, 2020, 02:30:50 PM »
You get some super finishes there Jim, very nice results.
Forging ahead regardless.
« Reply #147 on: January 20, 2020, 06:39:31 PM »
Nice work Jim!  I am inspired to get back at my shop projects, now that the holidays, and vacation trip, and driving the youngest boys back to their respective schools has all been done, and the snowfall and tree falls have been cleared from the driveway...for now?  :)
« Reply #148 on: January 20, 2020, 07:19:14 PM »
Nice work on the gland Jim. Hoping I can get back to my #5 soon, will be following your lead now :)
« Reply #149 on: January 20, 2020, 11:08:01 PM »
I was surprised by the gland. I haven't looked at the drawings for the #5 but when I first saw the gland, I thought the 'boss?' would be external.
Is there a reason why it's on the inside?
