Author Topic: Chris's Marion Valve Winding Engine  (Read 44984 times)
Offline tghs
Re: Chris's Marion Valve Winding Engine
« Reply #375 on: December 01, 2019, 12:27:20 AM »
cool now I reason to buy a boring head for my mill..
what the @#&% over
« Reply #376 on: December 01, 2019, 12:38:51 AM »
Very handy tool. Well worth getting a decent boring bar(s) too, the cheap brazed-on carbide ones are worthless as they come, without a lot of grinding work. Best add on tools for the mill, at least for what I use the most, are a good screwless vise, rotary table (able to be mounted horizontal and vertical), and boring head.
« Reply #377 on: December 01, 2019, 01:25:28 AM »
Chris--I haven't said very much, but I am following your thread each day. You do very nice work and give great explanations of what you are doing and why you are doing it. Great stuff!!!---Brian
« Reply #378 on: December 01, 2019, 03:05:02 AM »
« Reply #379 on: December 01, 2019, 04:33:28 PM »
Looks like the next project will finally be the Stanley engine!
 :pinkelephant: :pinkelephant: :cartwheel: :cartwheel: :pinkelephant: :pinkelephant:
Offline Firebird
  • East Midlands UK
« Reply #380 on: December 01, 2019, 04:45:19 PM »
 :popcornsmall:
Rich
« Reply #381 on: December 01, 2019, 10:18:31 PM »
Got the rest of the first eccentric bore out to the size of the slot on the follower, then took a partial-depth cut on both sides to form the rib in the center to match the width of the slot. The first side was already lined up from boring the main hole, but for the second side the part has to be flipped over and re-centered. I was about to get out the indicator, when I realized that I could just reset the boring head to the diameter of the first hole, and adjust the position of the mill table till turning the head by hand made it just scrape around all sides evenly. Then, knew it was centered and ready to cut - less time spent swapping tools around for the same result.
Here is what the rib in the center looks like with the two halves unbolted, and a little filing to remove the bur left by the cutter.
So, one down, starting on boring out the second one...
« Reply #382 on: December 03, 2019, 12:52:15 AM »
Noticed I forgot to post the picture of both followers bored out ready to shape the outside edges. Been getting things ready for next RC sub run at the pool this weekend.
« Reply #383 on: December 03, 2019, 08:23:56 PM »
Started shaping the outsides of the followers today. Started by milling in the slot for the arm up to the valve rod to fit into, then cut the straight section at the end around the slot:
Then moved the part out about 3" from the center to cut the curve that connects the flanges to the slot around the arm:
Got that cut made on both followers, next will mill the curve on the bottom half...
« Reply #384 on: December 04, 2019, 03:16:49 AM »
Nothing like some good Sherline "Etch-A-Sketch" machining!
Hope the snow doesn't get too deep back there.
« Reply #385 on: December 04, 2019, 06:45:13 PM »
This morning started in on rounding off the bottom caps for the eccentric followers. On smaller ones I would have used the trick of milling in the vise with a drill rod for a guide, but there would have been a lot more passes on these, plus I already had the rotary table set up.
« Reply #386 on: December 04, 2019, 07:29:49 PM »
 :ThumbsUp: :ThumbsUp: :ThumbsUp:  :popcorn: :popcorn: :popcorn: Oh , and some extra for the shop elves Chris :  :popcorn: :popcorn: :popcorn: :popcorn: :popcorn: :popcorn:
« Reply #387 on: December 04, 2019, 07:48:14 PM »
Chorus of little burps from the shop - they say thanks!
« Reply #388 on: December 04, 2019, 07:51:51 PM »
Got the second bottom half shaped, and both assembled onto the model. Also added the arms that lead up to the valve rods, riveted in place into the notches made the other day.
And whipped up the clevises (clevii? cleviseses? Those things! ) to join to the valve rod ends, as well as a pair of shoulder bolts for the pivots.
I think the next step will be the valve sliders/rods. Getting close to done on the engine parts, though still need to make the throttle body/slider/lever/pipes to make it all go....
« Reply #389 on: December 04, 2019, 09:27:02 PM »
Still with you Dog and she’s looking great........ :Love:
 :drinking-41:
