Suggestion for plating inside bores - place the nickel rod inside the bore, and use as many ground clamps as possible on the cylinder, all along and around it. Sometimes a tube shaped electrode works better inside bores. However, in my limited experience with plating, any bore plating I have done did not adhere well and had thin spots. For these reasons I would not use it if the bore had other parts running in it, like a crosshead guide or cylinder bore. Those applications did not go well for me.
Electricity always wants to take the 'short'-cut!
Hi Chris,In my brief experience to plating forty years or more back, the electrode placement was as much an art as a science. Movement of as little as an eight of an inch would result in bad plating, and dunking parts in boiling acid was no joy ether. I left after four months, six pair of safety shoes and countless shirts and pants got destroyed. The final straw was when one of the other workers wanted the afternoon off and dropped a pail of cyanide solution in the acid bath. This was the third time he had done it in the four months I was there.Gerald.
Given that the engines on the Marion were single, each with its own valve and control, I'm wondering how you're going to get one valve to control both engines simultaneously. What am I missing?
