Here's my question. High pressure cylinder is at TDC, steam is being admitted into the cylinder and pushing the piston downward. Exhausted steam is moving from the bottom of the cylinder into the Intermediate pressure cylinder but with the crankshaft at 120 degree spacing the I.P. piston is already on it's way upward. Exhaust from the I.P. cylinder is moving to the L.P. cylinder but the piston in that cylinder is already 120 degrees into it's stroke. When the engine gets reversed the steam entry seems to be more convoluted. What part of the engineering am I missing here?
Quote from: gbritnell on September 05, 2019, 05:38:19 AMHere's my question. High pressure cylinder is at TDC, steam is being admitted into the cylinder and pushing the piston downward. Exhausted steam is moving from the bottom of the cylinder into the Intermediate pressure cylinder but with the crankshaft at 120 degree spacing the I.P. piston is already on it's way upward. Exhaust from the I.P. cylinder is moving to the L.P. cylinder but the piston in that cylinder is already 120 degrees into it's stroke. When the engine gets reversed the steam entry seems to be more convoluted. What part of the engineering am I missing here?The eccentric for the HP valve is at a different angle to that of the IP and LP cylinders to alter the admission timing. On the Stuart it is 30 degrees (HP) and 15 degrees (IP & LP)… Its a bit of a fudge Jo
There has been at least one earlier thread here about this subject on this site and the easy answer is that no full size expansion engine has 120 degrees between throws. The debate concerned what angles then should be used and why + difference between air and steam in this application.I hope this will point your attention in a usefull direction, George.Best wishesPer
In many engines, HP cylinder have piston valve and slide valves in the IP & LP cylinders, hence valve settings are obviously different.And some engines don't have a receiver in its own, but simply large piping and steam chest !
