Author Topic: Tiny triple expansion steam engine  (Read 6870 times)
Re: Tiny triple expansion steam engine
« Reply #60 on: October 30, 2019, 10:59:56 PM »
I'm going to call this engine complete. It does run on air but not real well but I guess that's to be expected. When it loosens up a bit more I'll post a video of it. I made the els for the pipework. I turn the piece, drill it then use a ball mill to do the inside at the corner. This gives me stock so that the outside radius won't break through.
Many years ago when I needed small fittings I made this small double V-block fixture. One half of the el is turned then put in the mill and cut off at 45 degrees with a small slitting saw. The piece is them put on the end of a rod and mounted in a V-block. The other piece is mounted then the two pieces brought together leaving a minute gap for the silver solder. I took a picture prior to soldering but it was out of focus so the good picture shows the part after soldering. The radius is then filed and the fitting polished.
« Reply #61 on: October 30, 2019, 11:02:11 PM »
Some photos of the finished engine.
« Reply #62 on: October 30, 2019, 11:46:17 PM »
Another real beauty!   :praise2:
I like that method for the elbows, have to give that way a try!
ChuckKey
« Reply #63 on: October 31, 2019, 12:35:21 AM »
Very impressive, especially as it has only taken a couple of months, I think. I would be interested to know if applying a vacuum at the exhaust made a difference to the way it runs on air.
« Reply #64 on: October 31, 2019, 05:21:39 AM »
Beautiful work, George, as always!
Offline john mills
« Reply #65 on: October 31, 2019, 08:16:29 AM »
Magnificent  looking engine and in such short build time .i wonder if it will run better with a load that gets the pressure up in the high pressure  cylinder  so that there is some left by the time in expands to the low pressure
cylinder .
« Reply #66 on: October 31, 2019, 11:16:25 AM »
Amazing result George  :praise2:  :praise2:
Beside more running time, I can't think off anything else beside the above suggested Vacuum on the exhaust, that could improve running of an tripple expansion engine on air ....  :noidea:
Offline Johnmcc69
  • Erie Pa., USA
« Reply #67 on: October 31, 2019, 03:21:06 PM »
Absolutely beautiful work George! Really nice (tiny) details.
  :praise2:
Online Vixen
« Reply #68 on: October 31, 2019, 04:44:24 PM »
Very, very nice Gorge.  :ThumbsUp: :ThumbsUp: :ThumbsUp:
If ever I were to build a steam engine, it would be one like this
« Reply #69 on: October 31, 2019, 08:07:53 PM »
Interesting way to make elbows.  I guess I’m lazy but I just buy the castings.  :shrug:
The Tripple is just gorgeous, your attention to fine detail just makes the model ‘pop’.   :cheers:
