Hello Simon,I have some of these concave corner rounding end mills. They are intended for breaking/ radiousing the edges of flat plate work.Unfortunately they will not do as a substitute/ replacement for a ball nose end mill. For that we need a convex radius, like a conventional end mill with the corners ground off. Still lookingMike
Model engineers often have to carve/create the external 3 dimensional shapes to represent a casting or forged item, It's a problem the original manufacturer never faces.
...we need a convex radius, like a conventional end mill with the corners ground off. Still looking
Even a basic machine and basic software can produce good results
