Now if only you would stop playing with those radials and make something that needs a long crankshaft
The Y direction issue seems obvious once you see it. The easiest "fix" is just to reverse the sign of Y in line 30.
Yes. Change Y[#<Y>] to Y-[#<Y>]A parameter at the top (1 or -1) could work, but it would need to be documented in comments based on whether the top of the rotab move away or towards you.
