Author Topic: Teflon gasket material  (Read 1628 times)
Offline Rustkolector
« on: August 26, 2019, 11:56:12 PM »
I am in need of two square feet of 1/64" (.0156") thick Teflon sheet material for engine gaskets. No other thickness will work because of a dimension stack-up issue. Great stuff for gaskets. It has been a while since I purchased any, and I forgot where I purchased the last stock. Any help is greatly appreciated. Thanks.
Jeff
Re: Teflon gasket material
« Reply #1 on: August 27, 2019, 12:24:43 AM »
McMaster has .015" and thinner.
Offline stevehuckss396
  • Sterling Heights, MI USA
« Reply #2 on: August 27, 2019, 12:47:45 AM »
Offline Ian S C
« Reply #3 on: August 27, 2019, 12:26:40 PM »
I have used plumbers Teflon tape as a gasket on hot air motors, although I usually try for metal to metal joints.
Ian S C
