Author Topic: Tailstock die holder  (Read 1719 times)
« on: August 04, 2019, 08:15:15 AM »
For a long time I have been using a cheap imperial tailstock die holder with metric dies. The fits, especially for the 20mm die in a 20.9mm (13/16) hole, were not good and resulted in some slightly undersized or tapered threads. The MT1 - 16mm mandrel seemed ok so I decided to make a new metric holder. I did think about boring and sleeving the existing body but I still have some imperial dies.
I selected a piece of close enough 35mm diameter 90mm long mildish steel bar from the shelf. This was faced both ends and skimmed to remove the brown coating. I had a long 2.5mm drill that would just go through with about 4mm to hold in the chuck and starting with a stub drill and then a normal drill I got all the way through without disaster. Next I went through 10mm and finally 13.5mm (the largest MT1 size). As the tailstock stroke is only 40mm there was a lot of sliding the tailstock in and out (just as well it has a new knob  :) )
I tried to see if I could bore from one end but the compound slide hit the tailstock. I could have made various solutions but decided just to bore from both ends.
Re: Tailstock die holder
« Reply #1 on: August 04, 2019, 04:47:49 PM »
Having bored to 15.8mm from both ends I finished the bore with a 16mm hand reamer. There was no detectable transition/ridge in the bore and it was a good fit on the mandrel. With just residual cutting fluid as a lubricant the mandrel took several seconds to fall out under it's own weight  :) I then machined the 20mm die socket and turned it round to cut the 25mm end. Although the working ends were a long way from the chuck I found that with some gentle taps from a soft hammer I could get it running concentric to better than  0.05mm. Finally I cut some grooves like the original, I'm not sure if they serve a real purpose but I think that it looks better with them. Next step sort out some adaptors for 16mm and 12mm dies.
« Reply #2 on: August 04, 2019, 06:07:04 PM »
Nice looking die holder, Roger!
Looks like you'll be getting a much better die fit with the new one!
« Reply #3 on: August 04, 2019, 06:34:16 PM »
It seems the only M2.5 x 0.45 dies I can find are also 20 mm diameter.  Fortunately, my homemade die holder is 13/16 on one end and 1" on the other.  I intend to make a sleeve 1" diameter with a 20 mm hole and a transverse hole to permit an extra long setscrew to pass through and lock the 20 mm die in place.
Damn the inferial system.
« Reply #4 on: August 08, 2019, 05:42:44 PM »
One day the world might become standardised  ::)
Next up was an adaptor for my 16mm dies. This was made from an end of 25mm bar drilled through 10mm. I opened out most of the recess with a 14mm end mill and finished off with a boring bar. I previously made an adaptor for 12mm dies that had a 20.8mm diameter that I decided to skim down to 20mm. As this was fairly narrow I supported it with a piece of 6mm ss rod held in the tailstock chuck. The last turning operation was handle from a piece of 8mm rod. I saw no point in the knurling on the original so left it plain but rounded.
To get the 45° angle between the clamping screws I decided to use the Proxxon dividing head on the Proxxon drill. For tapping I used the chuck key for added leverage.
« Reply #5 on: August 08, 2019, 10:03:07 PM »
Looks like you will end up with at nice new tool Roger  :ThumbsUp:
Yeah well .... the new Brexit Government has announced that they will drop the Metric system and go back to the Infernal system in order to Make Britain Great again  :insane:   :Doh:   :facepalm:  but what do you expect from another set of morons in charge ...!... sorry I will stop here.
Offline Ian S C
« Reply #6 on: August 09, 2019, 04:22:39 AM »
OK about going back to imperial(you never really left it), but manufacturers are all set up for metric, and your future market is mainly metric. I I suppose smeone will suggest going back to 20 shillings in a pound, 12 pence in a shilling. Maybe pounds and ounces for weight.Can't the silly B*&&^% see that changing from where you are now will put you back 50 years, an cost you for ever. Forget it.
Ian S C
« Reply #7 on: August 10, 2019, 08:12:10 AM »
Final step, drill and tap the 16mm adaptor. After a quick polish and Loctiting the handle in place its ready for anything  :wine1:
As an aside I realised that if I assemble the adaptors so the clamping screws are on the opposite side to those on the main body the tolerances will cancel out  ;D
« Reply #8 on: August 10, 2019, 05:23:10 PM »
Very nice little tool you made, Roger.  :ThumbsUp:
Now we need to see it in action!
« Reply #9 on: August 10, 2019, 05:32:41 PM »
Action is planned  :) I was prompted to make this due to problems with the threads on the new series of fuel injectors. The offset together with a sharp die and a brass workpiece was resulting in undersize threads which may fail under pressure  :(
