Author Topic: Webster build- inlet valve spring  (Read 1303 times)
Offline John Rudd
« on: August 01, 2019, 09:48:05 PM »
What are folk using for the inlet spring?
Having difficulty with the right stuff...
TIA
Eccentric millionaire sponsored by 'Er indoors
Re: Webster build- inlet valve spring
« Reply #1 on: August 01, 2019, 10:09:10 PM »
While I admittedly haven't got a clue what the dimensions are - a lot of people here use music wire, as in guitar strings - sizes are from 0.08" to around 0.24" as unwound - bigger diameters would be piano-wire.
Best wishes
« Reply #2 on: August 01, 2019, 11:54:05 PM »
If you have the Webster plans, the spring information is given on the sheet which shows the assembly of the valve body. The critical things are the inside diameter of 0.188"--Can't be less than that or the spring won't fit over the tapered valve guides. The wire diameter is also given. Free length of the spring is rather subjective. The intake spring has to be strong enough to pull the valve shut, but weak enough that the engine vacuum can pull the valve open against spring pressure. The exhaust valve is opened mechanically by the rocker arm, so it's spring  can be heavier. Only other thing is to check and make sure that the exhaust spring, when compressed fully, isn't longer than the lift of the camshaft. Go to your local nuts and bolts store, take a piece of 3/16" rod with you to test for inside diameter of the spring by sliding the spring over the rod. Take a Vernier caliper with you to check the wire diameter.  My sources in Canada are Brafasco and Fastenall.
