Author Topic: MINI BELT SANDER  (Read 3660 times)
Re: MINI BELT SANDER
« Reply #15 on: August 04, 2020, 05:14:12 PM »
George:
Is there any way you could modify the sander to take the more readily available 394mm (15-1/2") belts?  They aren't available in the 20mm width either, but splitting a wider belt to a narrower width has GOT to be easier than cutting and splicing a belt to the 330mm length.
Offline mechman48
  • Retired maint.Eng.
« Reply #16 on: August 07, 2020, 05:10:49 PM »
Hi Don
Have not looked at this aspect but have managed to make up 4 spares as mentioned in previous post & still have quite a few 10mm left so am not without at the mo. I'll certainly look at your suggestion (thanks).
George.
George.
