Author Topic: repair of an old stationary steam model  (Read 22182 times)
Offline rarach22
Re: repair of an old stationary steam model
« Reply #60 on: May 10, 2020, 09:43:16 PM »
the system is a Cochran boiler, many things are according to my drawings....
Online Roger B
« Reply #61 on: May 11, 2020, 11:09:43 AM »
Ah yes, I remember Florian making a Cochran boiler.
Offline rarach22
« Reply #62 on: May 23, 2020, 12:56:25 PM »
Offline rarach22
« Reply #63 on: June 30, 2020, 09:08:11 PM »
Offline Johnmcc69
  • Erie Pa., USA
« Reply #64 on: June 30, 2020, 09:34:40 PM »
 :praise2:
 Beautiful work as always Pavel!
 Looking forward to the first run!
Offline rarach22
« Reply #65 on: July 09, 2020, 11:26:48 PM »
« Reply #66 on: July 10, 2020, 02:41:58 AM »
Hi Good progress... But just wondering how you manage to put 50 photos on your post as I thought it was only 8 permitted ??
Willy
« Reply #67 on: July 10, 2020, 03:05:08 AM »
Willy
You can attach 8, but if you embed the photos as links from a hosting site, you can do as many as you want.
« Reply #68 on: July 10, 2020, 03:14:18 AM »
Willy
  Ok Chris.  :ThumbsUp:
thanks...
willy
« Reply #69 on: July 10, 2020, 05:45:55 AM »
Hi Pavel.......we see your 4 bolt and 5 bolt flat-faced rising spindle valves [we have spoken before]
For my gaskets, I am using a course grained paper, soaked in salt water + dye........the result is a 0.33mm thick and absolutely rigid before stamping the hole pattern
This 0.33mm thickness at a scale of 1:20 = ~~ 6.6mm thick gasket which is too thick & totally out of scale, but so far it has been suitable for 3 Bar steam and the same 3 Bar for make-up water.......
I have used gasket paper of ~~0.15mm thick, but found it too fragile to use.... :thinking:
My question is 'what thickness flange gasket material, and type of fibre paper are you using?'.....
Derek
« Last Edit: July 10, 2020, 08:13:44 AM by derekwarner »
Offline rarach22
« Reply #70 on: July 10, 2020, 11:14:01 AM »
Willy
Ah, I guess I missed that
Offline rarach22
« Reply #71 on: July 10, 2020, 11:31:59 AM »
https://eshop.atstrutnov.cz/cs/hledani/1/9/932-10070025
https://eshop.atstrutnov.cz/cs/hledani/1/9/932-71255005
https://eshop.atstrutnov.cz/cs/hledani/1/9/932-10070050
hello, sorry for the Czech links ..... I bought a seal from this company that absolutely meets the requirements
Derek
Offline rarach22
« Reply #72 on: July 10, 2020, 11:33:14 AM »
recommended for the production of seals: petrol, kerosene, diesel, mineral and synthetic oils, glycerin, ethylene glycol, chlorine, hydrogen chloride, isooctane, potassium cyanide, acetic and formic acid, turpentine, toluene, xylene. Max temperature 450 ° C for a short time, 330 ° C for a long time, steam 250 ° C for a long time. Max pressure 120 bar, According to DIN DIN 28 091-2: FA-M-1-0 (ST). Suitable for the production of tub seals, suction pipes, oil connections, valve covers, gearbox covers.
Derek
Offline rarach22
« Reply #73 on: July 10, 2020, 11:35:17 AM »
Offline rarach22
« Reply #74 on: July 10, 2020, 08:41:41 PM »
