Author Topic: repair of an old stationary steam model  (Read 8497 times)
Offline rarach22
Re: repair of an old stationary steam model
« Reply #30 on: September 28, 2019, 12:25:11 PM »
Hi Derek, the hoop valve will be connected to the Watt controller. I use five screws for larger flanges. (aesthetics) Usually for pipe 4mm 4 screws and 8mm 5 bolts. It's my style.
« Reply #31 on: September 28, 2019, 11:42:01 PM »
Offline rarach22
« Reply #32 on: October 22, 2019, 08:54:47 PM »
Offline rarach22
« Reply #33 on: October 22, 2019, 09:00:00 PM »
« Reply #34 on: October 23, 2019, 03:58:18 AM »
Amazing work Pavel....just two questions
1. was the Blue gasket material too tough and incompressible with scale torque?.....the Straw cardboard looks torn on the edge so was softer & more suitable?
2. Is this some sort of flared tube fitting in the second image?
Derek
« Last Edit: October 23, 2019, 07:39:36 AM by derekwarner »
« Reply #35 on: October 23, 2019, 05:07:36 PM »
Splendid as ever  :praise2:  :praise2:  :wine1:
Offline rarach22
« Reply #36 on: November 02, 2019, 04:10:43 PM »
Offline rarach22
« Reply #37 on: November 09, 2019, 09:55:07 PM »
Offline rarach22
« Reply #38 on: November 17, 2019, 07:54:19 PM »
Offline rarach22
« Reply #39 on: December 01, 2019, 09:36:03 AM »
Offline MJM460
« Reply #40 on: December 02, 2019, 06:46:01 AM »
Hi Pavel,
Great to see a governor actually controlling the speed of the engine when you varied the load with your fingers on the flywheel.  It looks like you were also able to alter the set speed with the spring preload.
Really excellent work, right up with your normal high standard.  Really great to see.
Offline rarach22
« Reply #41 on: December 15, 2019, 06:14:29 AM »
« Reply #42 on: December 15, 2019, 07:28:44 AM »
Looking good  :praise2: Those pin gears are interesting  :)
Offline rarach22
« Reply #43 on: December 27, 2019, 10:05:53 PM »
Offline rarach22
« Reply #44 on: December 29, 2019, 05:34:41 PM »
