Author Topic: Half Fast Tap extension  (Read 4946 times)
Offline Captain Jerry
  • Summerfield, FL USA
« on: October 31, 2012, 11:32:24 PM »
I wasn't satisfied with how my new flywheel was running so I decided to make a new hub but this time I waited until the hub was seated and the flywheel was running true in the lathe before boring the hole for the shaft.  OK so far. Now drill and tap the hub for a grub screw.  Oop!
I set the flywheel at an angle in the vise to get better access to the hub and was able to drill with a long series bit but there was no way the tap was going to reach.  Here is my quick solution.  I nailed it.
Hole drilled in nail as close as possible to the tap body diameter.  Insert tap.  Crimp the nail once against the body of the tap and twice, at 90? where the flats are at the top of the tap.  I left the nail head on so you could see what it was, but you could turn that off for better clearance.
I don't think it will be hard to remove it but I dont see a need to right now.
Jerry
« Last Edit: October 31, 2012, 11:35:33 PM by Captain Jerry »
NOTARY SOJAK
Offline rebush
Re: Half Fast Tap extension
« Reply #1 on: November 01, 2012, 12:20:09 AM »
Captain Jerry: Great idea! Will store that one away for future use. Thanks. Roger
Hopelessly lost but making darn good time.
Arbalest
« Reply #2 on: November 01, 2012, 09:02:15 AM »
Handy tip, thanks!
« Reply #3 on: November 01, 2012, 11:34:35 AM »
Yep that's useful. I'm saving that idea too.
Offline black85vette
  • Rick in Yukon, OK
« Reply #4 on: November 01, 2012, 12:07:38 PM »
I have run into that several times.  Nice solution.
Offline ScroungerLee
« Reply #5 on: November 01, 2012, 04:18:51 PM »
Wow that is great!  I have faced that situation many times, as I am sure others have.
This is a definite "to remember" solution that I have never seen before.
Lee
Mmmmm.... Shiny!
« Reply #6 on: March 03, 2013, 09:58:54 AM »
Thanks Jerry
I need to remember this trick for my Corliss flywheel.
« Reply #7 on: March 03, 2013, 11:35:43 AM »
Nicely done Jerry!   I like that....Hell I'd frame that!   :ThumbsUp: :cheers:
Offline peatoluser
  • liverpool UK
« Reply #8 on: March 03, 2013, 05:59:45 PM »
I agree wholeheartedly with the above comments.
it's tips like this make the forum great. nice one Jerry!
Peter
Offline ths
« Reply #9 on: March 04, 2013, 01:04:34 AM »
Great idea, thanks.
Hugh.
« Reply #10 on: March 04, 2013, 03:09:24 AM »
Thanks for the comments.  I posted this four months ago and it seems like a lot of people missed it then.  I wonder how many useful thing I have missed.
Jerry
NOTARY SOJAK
Offline larry1
« Reply #11 on: March 04, 2013, 03:52:09 AM »
great job, captain jerry, hope i can remember this when i need it again.     larry
larry, southeastern kansas
