What kind of tool do you use to get square corners on the center throw? I always have a problem with leaving a fillet in one or both corners or having a step in the journal if I change tools to RH or LH.
I would say that is an advantage, you don't want tight internal corners as they are stress risers, I always leave a small fillet and turn a CSK on the bearings and big end to clear it.
