Author Topic: Die Filer attachment for the lathe  (Read 1286 times)
Online Twizseven
Re: Die Filer attachment for the lathe
« Reply #30 on: June 09, 2019, 12:44:46 PM »
Dave,
Those files look good.  Can you confirm a couple of things for me.
What is the diameter of the shank, I need to ensure will fit in the Excel clamp mechanism.  On the basis these are clamped below the table do the files all cut on the down stroke.
Cheers,
Colin
« Reply #31 on: June 09, 2019, 02:05:24 PM »
Hi Colin    Ill measure them up today and report back here
« Reply #32 on: June 09, 2019, 09:23:36 PM »
Hi Colin
I measured up 3 and got a range of 0.248" to 0.251"   (6.30mm to 6.375mm)  The shanks are soft.
They all cut on the down stroke
They are made by Nicholson, a pretty well respected file company in the day. and are die filer files, not modified hand files
Online Twizseven
« Reply #33 on: June 10, 2019, 12:48:24 PM »
Dave,
Thanks for that.  They will fit in the Excel clamp mechanism.  I made some small steel blocks and drilled them out to use chainsaw files.  I used Araldite to secure the files.
This works well, so could repeat if necessary for these.
Colin
« Reply #34 on: June 13, 2019, 02:07:33 AM »
A little more done tonight
