Author Topic: 15cc Seal and 30cc Seal Major  (Read 31352 times)
Online Alyn Foundry
Re: 15cc Seal and 30cc Seal Major
« Reply #180 on: August 15, 2019, 02:58:37 PM »
Hi Both.
Jason does have a good memory Jo....
But you're right, I've decided not to sell as I don't know what's hidden beneath the surface of these goodies.
Cheers Graham.
Online Jasonb
« Reply #181 on: August 15, 2019, 03:05:33 PM »
Did not remember what was in the photo though  :-[, I now see bases for two CHUK varients there.
Out of interest what engine were the smaller curved spoke flywheels for and what diameter.
Online Alyn Foundry
« Reply #182 on: August 15, 2019, 03:27:02 PM »
Hi Jason.
As always, there's a story.
They came from a small atmospheric gas engine who's picture appeared in an article written in the Model Engineer circa 1905.
Dave Croft, a familiar face on the NW stationary engine rally scene acquired this very engine many years ago. He approached me because the delicate spokes had been broken just inside of the flywheel rim. I managed to repair one to be used as a pattern to replace the broken ones.
They are 5" in diameter with a rim depth of 1/2" but are quite light, ideally suited to non compression engines.
I used them for Nattie, my little National Gas engine " lookalike " flame gulper.
<a href="https://www.youtube.com/watch?v=2eorVwM7n64" target="_blank">http://www.youtube.com/watch?v=2eorVwM7n64</a>
Cheers Graham.
Online Jasonb
« Reply #183 on: August 15, 2019, 04:03:48 PM »
I always like story time, sent you a message.
« Reply #184 on: August 15, 2019, 04:06:27 PM »
Don't let him have any of the castings Graham  :hellno:
You know what he says about castings  :slap:
« Reply #185 on: August 15, 2019, 04:51:17 PM »
A bit more on the Major rods. You will recall the holes top and bottom of the rods looked decidedly out of line relative to the castings - its time to fix that.
Using the bored holes to hold the conrods the outsides have been taken to width and given a bit of a running face. I have chosen to make the big ends 12.5mm wide rather than the 12.7 in the drawing because the drawings have no tolerances  :ShakeHead: A 12.7mm rod on a 12.7mm big end, when you think there are 4 of them doesn't leave any wiggle room same goes with the little ends - the drawings show the same width as the counter bored inside the piston  :facepalm:
I know, I know the rods still look all out of line but if you put two bars through the bored holes you can see they are in line  :)
The next part is mainly cosmetic. The bottom ends need to have their outsides turned to 22.2mm diameter (this still won't let them be inserted into the engine through the bore  :disappointed: ) and the rods need to be fettled so they all weigh the same.
 :thinking: I wonder if someone has some new castings he would like to share with me  :wine1:
« Reply #186 on: August 15, 2019, 05:26:11 PM »
Looking much better than when you started on them  :praise2: Not that long till the first trials  :)  :)  :wine1:
« Reply #187 on: August 16, 2019, 04:36:01 PM »
Thanks Roger  :)
To turn the outside of the rods to the required 22.2mm I used the big end bolts to secure the rods to a piece of spare bar and proceeded to turn the outside of the big end.
Each big end cap in turn had the counterbore added for the screws and a slight step across the width added. The castings did not have enough material to round the cap like the drawings :(
The last stage took the longest as it involved lots of fettling: Partly to give them a better shape but mainly to get the small end to fit into the bottom of the pistons and to make sure they all weighed the same. The final rods are within 0.1g of each other  :D
I now have the joys of repeating this for the Seal rods, but as they are barstock they will be somewhat easier to do and will use a totally different machining process.
Offline Bearcar1
  • Chicagoland Area, USA
« Reply #188 on: August 16, 2019, 08:35:05 PM »
WoW!! Nicely done Jo…… I Like it a lot!!   :DrinkPint:
BC1
« Reply #189 on: August 17, 2019, 07:04:52 AM »
Thank you Jim, nice to see someone else following along on these builds :)
« Reply #190 on: August 17, 2019, 11:33:37 AM »
I heard a startled noise and found a delivery driver being hassled by Surus    :facepalm2: He clearly was holding an engineering parcel as it was held together by the duct tape on the outside  :thinking:..
Closer examination found it contained a set of castings with that patented special coating so I did not need to read the further clue on the base (which read "Chuk Alyn Foundry" ) to know where it originally came from  :pinkelephant:
Lets hope Surus is feeling generous and we can have a fondling session later  :naughty:
« Last Edit: August 17, 2019, 05:31:25 PM by Jo »
Offline Bluechip
  • Derbyshire
« Reply #191 on: August 17, 2019, 11:41:45 AM »
 Hi Jo
:whoohoo:  :cartwheel:   :wine1: etc. etc.
Online Jasonb
« Reply #192 on: August 17, 2019, 04:06:57 PM »
Lets hope he is feeling generous and we can have a fondling session later  :naughty:
I'm sure he would swap the licker for a Snicker ;)
« Reply #193 on: August 17, 2019, 04:57:49 PM »
I think you are underestimating Surus: I might get to fondle it for the time it takes him to eat the snicker  :noidea:
He tells me something is missing the plans detail an A frame and he doesn't have any in his set :facepalm:
Online Jasonb
« Reply #194 on: August 17, 2019, 05:26:51 PM »
That is all I had to go on when I built Chuky, seven written sheets plus a couple of photos of Grahams. You can just about do him at 1.5 times and you will have a totally metric engine too if you can't manage without drawings.
« Last Edit: August 17, 2019, 05:31:16 PM by Jasonb »
