Author Topic: A different carburetor thread---  (Read 1407 times)
« on: May 31, 2019, 04:43:38 PM »
Yes, I do make my own carburetors. The throttled carburetors that I make are almost an exact copy of those made by Malcolm Stride for his Bobcat and Jaguar engines, and they give remarkably good results. I make carburetors for my hit and miss engines as well, and I have varying results. In the picture you will see a carburetor that I copied from an old Upshur hit and miss engine. I got lucky and it worked very well. My problems with this style of carburetor are #1--There is simply no way that I can form a perfect taper on a #2-56 bolt, nor can I accurately make a fully threaded 2-56 needle. Problem # 2 is that the two small "tubes" that the needle pass thru are separate pieces, and even with a jig it is nearly impossible to line them up perfectly. They have to be aligned perfectly because the needle screws into one side, and the taper of the needle must fit perfectly concentric into the fuel delivery hole in the other piece. There is another way to do this as suggested by Philip Duclos, where the two separate pieces are made as one complete single piece that runs completely thru the carburetor body, thus eliminating any concentricity problems.
Re: A different carburetor thread---
« Reply #1 on: May 31, 2019, 05:12:03 PM »
This is typical of the Philip Duclos carburetors, and you can see the one piece "fuel rail" which goes completely thru the carb body and is secured with a hex nut on one side. The small hole in the center lines up exactly with the center of the carburetor bore and faces "downstream" of the air flow. These carburetors function quite well.
« Reply #2 on: May 31, 2019, 05:13:17 PM »
One of the truly great things about the Duclos design is that the needle is exactly that--a sewing needle. It fits thru a hole in the center of the "Top screw" and is slid down thru until it seats perfectly in the small hole in the fuel rail. The fuel rail has a threaded outside diameter and the "Top screw" is large enough to have a thread on the i.d. You assemble the fuel rail into the carburetor body, screw the "Top screw" down until it bottoms out against the carburetor body, then back it off two full turns, push the needle down until it is seated, then snip off any needle which sticks up past the Top Screw and silver solder the needle to the Top Screw at the top.---------The thread on the inside diameter of the Top screw and on the outside diameter of the fuel rail is a #10-40 thread.--a 10-32 thread would work here also, but doesn't give you the fine adjustment that a 10-40 thread does.
« Reply #3 on: May 31, 2019, 05:19:21 PM »
I do find that on Duclos style carburetors that they perform better if after assembly a bit of "seal all" is put around the hex nut and the fuel rail where it emerges from the carb body so the carb can't suck air thru the joint. Even a small air leak will affect the amount of venturi vacuum that the carburetor can create. Venturi is the effect that creates vacuum when an airway is suddenly reduced in size, as in "partially plugged" by the body of the fuel rail. It is this venturi effect that lets the carburetor suck fuel up from a tank which is lower than the carburetor.
« Reply #4 on: May 31, 2019, 09:59:33 PM »
Hang in there guys--I am going somewhere with this ramble.
« Reply #5 on: May 31, 2019, 10:36:15 PM »
I may have to play with the size of the oblong hole mentioned in the drawing in order to get a total flow rate equal to that of the previous drawing, but I'm in "try this and see if it works" mode.
« Reply #6 on: June 01, 2019, 03:16:58 PM »
I keep redoing things until I'm happy with the results. This is (I think) the final rendition of the carb. The cross section of the carburetor at the center of the needle valve ends up very close to what is on the carb now, so the total flow thru rate thru the carb should remain the same.
--Is anybody looking at this stuff??
Offline Johnmcc69
  • Erie Pa., USA
« Reply #7 on: June 01, 2019, 03:49:50 PM »
 :ThumbsUp:
 Good stuff Brian, keep it coming...
« Reply #8 on: June 01, 2019, 04:44:14 PM »
So--Just before the dance begins--This is the carburetor which has the needle made from a #2-56 socket head capscrew with a point which is not really good. The point was ground "by eye" and is a bit wonkey.
« Reply #9 on: June 01, 2019, 05:09:58 PM »
And here is the same carburetor with the fuel rail removed--sawing/grinding/drilling. the needle is put into my "jar of things to keep even if they don't work right."
« Reply #10 on: June 01, 2019, 07:21:59 PM »
Here we have carb body, fuel rail, and needle. I still have to make the cap that attaches to the needle.
Offline 90LX_Notch
    • YouTube Channel
« Reply #11 on: June 01, 2019, 07:41:47 PM »
What's the purpose of the 90 degree bend in the throat?  Is there an advantage over a straight throat?
-Bob
Proud Member of MEM
My Engine Videos on YouTube-
« Reply #12 on: June 01, 2019, 08:59:01 PM »
No advantage at all and better not to have it. In my case the needle valve was so close to the sparkplug that every time you went to change the setting, you would get zapped. I didn't care for that much, couldn't move the port or the sparkplug so the offset was put in to save me from electrocution.
« Reply #13 on: June 01, 2019, 11:36:59 PM »
So--Here we are, ready for solder. The white stuff is typewriter "Wite-Out" correction fluid. It keeps solder from sticking where you don't want it to go. I'm making this up as I go along, and one thing has showed up---When I put the fuel rail into the carburetor body, a little light bulb went off, and I thought--Why not just solder this fuel rail on the side opposite from the threads. Use a little "seal all" on the threaded side and that way the fuel rail will be firmly anchored in place with no danger of solder getting into the threads. Of course, immediately after I thought that, I remembered that the hole milled thru the fuel rail will effectively cut the fuel rail into two pieces, and the unsoldered side will fall out. So---it's going to get silver soldered on both sides. If I get any solder migrating into the threads, I will run the die over the threads to clean them up. I have put a 0.020" x 45 degree chamfer in the hole on the carburetor body closest to the threaded side of the fuel rail, and if I have lived a good life most of the solder will be in that chamfer.
« Reply #14 on: June 02, 2019, 04:23:13 AM »
Brian,
I have been following when life permits, busy weekend. My niece is having her wedding reception Sunday & lots of stuff has been happening at our house. On top of that my aunt & uncle were hosting my cousin and the twin great grandchildren and the proud parents on Friday. This seems like the first time I've sat down to myself all day. Your getting zapped by the spark plug lead reminds me of my dear old dads spark plug tester.
