Author Topic: Schaublin corner  (Read 5581 times)
Re: Schaublin corner
« Reply #15 on: May 26, 2019, 11:32:43 PM »
Saweeeeeet!.....
Online sco
« Reply #16 on: May 27, 2019, 11:18:01 AM »
Thanks Dave.  Next was to add the graduations, used a screwcutting insert turned on it's side and then after parting off the dial is finished.
Simon.
Ars longa, vita brevis.
« Reply #17 on: May 27, 2019, 10:24:14 PM »
Very nice work on that Dail Simon. Are you going to put numbers on it?
« Reply #18 on: May 28, 2019, 12:47:51 AM »
Beautiful and fitting for such a nice tool.
Online sco
« Reply #19 on: May 28, 2019, 09:27:58 PM »
Thanks Don and Bill and yes got some numbers on it, asked the inspection department at work to Laser engrave it - much better result than I could hope to achieve with stamps.
I've also cheated and bought a balanced crank handle but need to modify it to mate with the drive dog,
Simon.
« Reply #20 on: May 28, 2019, 10:46:59 PM »
Which ever works for you Simon very nice looking dial!
« Reply #21 on: May 28, 2019, 11:25:58 PM »
So nice to have friends in high places   ;), especially when they have laser engravers.
Online sco
« Reply #22 on: June 01, 2019, 11:38:27 AM »
Thanks Bill and Don.
As I said I cheated and bought a handle but it needed a square recess cutting for the drive dog.  The dial span on it's boss way too freely so I drilled a radial hole for a small sprung loaded brass plunger to provide a bit of friction.  Last picture is it all assembled ready for some rotary work.
The mill came with a slotting head so going to have a play with that next and try and cut a square hole  :noidea:
Simon.
Online sco
« Reply #23 on: June 02, 2019, 07:41:25 PM »
Setting up the slotting head took quite a while and had to start by grinding a simple chisel edge on a bit of tool steel.  Pictures show part way through the process, finished internal square and then after milling the outside faces to make a thin walled square tube.  Took a couple of videos of the process too.
<a href="https://www.youtube.com/watch?v=QrCtbjiY-Pg" target="_blank">http://www.youtube.com/watch?v=QrCtbjiY-Pg</a>
<a href="https://www.youtube.com/watch?v=AGHoABcz3-o" target="_blank">http://www.youtube.com/watch?v=AGHoABcz3-o</a>
Simon.
Offline Florian Eberhard
« Reply #24 on: June 02, 2019, 08:48:50 PM »
Nice! A slotting Attachment is a pretty cool thing! I don't have one but probably am going to build one when I have finished all my current projects :) (which is going to take another two or three years I am afraid)
Florian
« Reply #25 on: June 02, 2019, 10:21:53 PM »
Awesome result Simon love that machine!
