Author Topic: LANZ tractor  (Read 17807 times)
Offline Tapsa
Re: LANZ tractor
« Reply #15 on: May 25, 2019, 05:47:40 PM »
Offline Tapsa
Re: LANZ tractor
« Reply #16 on: May 26, 2019, 09:37:20 AM »
Flywheels are ready. The end of finishing yet
Re: LANZ tractor
« Reply #17 on: May 26, 2019, 02:05:45 PM »
Tapsa--Very nice work and a very interesting model. I will be following.---Brian
Offline Tapsa
Re: LANZ tractor
« Reply #18 on: May 26, 2019, 04:43:16 PM »
Thanks, I describe how the work is going on. Linking more photos later.
Offline Tapsa
Re: LANZ tractor
« Reply #19 on: May 26, 2019, 05:20:14 PM »
Next, there is the engine frame
Re: LANZ tractor
« Reply #20 on: May 26, 2019, 05:26:28 PM »
Some of your dimensions are picking up on the tangency points of the rounded corners instead of the line you intended to dimension. Especially in the lower right view.--Brian
Offline Tapsa
Re: LANZ tractor
« Reply #21 on: May 30, 2019, 03:45:08 PM »
crankshaft parts are silver soldered and polished ready
Piston
Offline Tapsa
Re: LANZ tractor
« Reply #22 on: June 02, 2019, 05:04:38 PM »
Not so many parts are ready compared with the time used
Re: LANZ tractor
« Reply #23 on: June 02, 2019, 07:19:54 PM »
There's  lot of work in each part  :praise2: 'm following along  :wine1:
Offline Tapsa
Re: LANZ tractor
« Reply #24 on: June 21, 2019, 01:49:22 PM »
Hello everyone, has been busy for two weeks. I haven't had a workshop at all. I was a Speedway race in Latvia. from the video you can see Latvian competitions. I do not run a race, I'm only sponsor of the team.
Tapsa
<a href="https://www.youtube.com/watch?v=IKX44162Wm0" target="_blank">http://www.youtube.com/watch?v=IKX44162Wm0</a>
Offline Tapsa
Re: LANZ tractor
« Reply #25 on: June 21, 2019, 01:53:11 PM »
Today I was able to do some parts again
Offline Tapsa
Re: LANZ tractor
« Reply #26 on: June 30, 2019, 12:24:56 PM »
Hey everybody. Fuel tank and other small parts, I had time to do
Tapsa
Re: LANZ tractor
« Reply #27 on: June 30, 2019, 09:34:28 PM »
They might not be the most sexy parts, but a part finished is another on of the list = progress  :cheers:
Offline michelko
Re: LANZ tractor
« Reply #28 on: July 01, 2019, 06:27:33 AM »
 :Mad:Nice work will follow this thread for sure. One question about the gear. The teeth look not right to me, have you used the number 7 cutter for this gear?
As far as i know the 7 cutter is for large number of teeth. A ten tooth gear should be made with the number 1 cutter
P.s. look at your cutter it says 55-134 tooth!
Offline Tapsa
Re: LANZ tractor
« Reply #29 on: July 01, 2019, 03:19:11 PM »
Hello, this parts not gear,
Tapsa
