If you put the large gear on the other way round you will then be able to access the small gears grub screw to fix it to th eshaft and then slide the larger gear already fitted to its shaft into place and screw on the side cover.Or put a hole in the bottom for access and slide the vertical shaft complete with small gear in from below if you want to keep the larger gear that way roundWhat did the original drawings show?
