Author Topic: V8 crank in a case  (Read 1218 times)
Offline galland
V8 crank in a case
« on: April 11, 2019, 04:52:08 PM »
Didn't know what else to call this. Sometimes I just get making something that doesn't really have any purpose at all. Just something to pass the time. Where I used to work I was in the gage room at one time and we had a boxload of very tiny gears that came out of old meters and dial indicators. I latched on to a bunch thinking maybe I could find a use for them some day. I used two here. Not sure what else to do with it now.       Gary
Offline galland
Re: V8 crank in a case
« Reply #1 on: April 11, 2019, 04:56:57 PM »
Woops,   meant to say V8 crank in a crate.       Gary
Offline Johnmcc69
  • Erie Pa., USA
« Reply #2 on: April 11, 2019, 05:28:38 PM »
Very cool! Nice work!
 "Not sure what to do with it?" ....
 Build the rest of the engine around it!  :stickpoke:
« Reply #3 on: April 11, 2019, 06:15:27 PM »
Yes!
« Reply #4 on: April 11, 2019, 09:41:41 PM »
Hello Galland,
I also vote for a completed engine, that is just way cool, you have to finish that project.
Have a great day,
Offline galland
« Reply #5 on: April 12, 2019, 01:34:02 PM »
I love your enthusiasm guys for me to do more with this. Originally I only wanted a crank that I could put those tiny gears on thinking a flywheel might look cute. Then I built the crate or whatever it is to hold it and be able to rotate it. I must admit then I got visualizing rods and pistons so I did some calculations and they did not look promising. The rod journals are right at .125 wide meaning the rods would have to be a little less than .062. Now you see those huge 0-80 screws holding the flywheel on. The heads on them are .096 across so way to big. I have heard that you can get 00-90 socket head screws but I don't know what diameter they are but 00-90 hex head are about .080 across the flats which is also way to big.      Gary
Offline stevehuckss396
  • Sterling Heights, MI
« Reply #6 on: April 12, 2019, 08:51:45 PM »
"I only wanted a crank that I could put those tiny gears on thinking a flywheel might look cute. Then I built the crate or whatever it is to hold it"
Yep! That's how it starts.
toolznthings
« Reply #7 on: April 13, 2019, 03:06:26 AM »
Very cool and nice work !   :ThumbsUp:
