Author Topic: Compressed Air V8 Engine  (Read 55597 times)
Offline DaveH
  • Kempton Park. RSA
Re: Compressed Air V8 Engine
« Reply #15 on: July 20, 2012, 02:12:38 AM »
Chuck,
Wow, some very nice machining   :) :) :)
Just wondering is there a reason to use magnesium for the block?
DaveH
Offline cfellows
« Reply #16 on: July 20, 2012, 05:07:33 AM »
Chuck,
DaveH
Thanks, Dave!  I used magnesium based on available stock.  I didn't have any aluminum the right thickness, only the magnesium, so that's what I used.
Chuck
Offline DaveH
  • Kempton Park. RSA
« Reply #17 on: July 20, 2012, 09:07:00 AM »
Chuck,
DaveH
Chuck
Chuck,
That's one of the best reasons  :D :D :D
DaveH
Offline spuddevans
  • Portadown, Northern Ireland
    • My photo website
« Reply #18 on: July 20, 2012, 11:56:36 AM »
Looking good, there is always something fascinating for me with V8's. I'm looking forward to watching this one grow.
Tim
Measure with a Micrometer, mark with chalk, cut with an axe. MI0TME
Offline metalmad
« Reply #19 on: July 20, 2012, 02:40:23 PM »
Hi Chuck
That Crank is lovely Mate
Offline Dean W
    • Home Shop Projects
« Reply #20 on: July 22, 2012, 04:06:29 AM »
Coming along great, Chuck.  I like the way you chose to remove the stock from inside the crankcase.
Is this engine going to use your special valve setup?  (Forgotten what you call it..)
Dean
In beautiful N. Idaho, U.S.A.
Shop Projects:
Offline sbwhart
  • Live Long and Prosper
« Reply #21 on: July 22, 2012, 06:59:31 AM »
I'm watching along Chuck this will be a superb engine  :)
Stew
Offline NickG
« Reply #22 on: July 22, 2012, 08:44:33 AM »
It will be, looking forward to watching this. Will never get anything of my own done that this rate   ;)
Nick
Offline cfellows
« Reply #23 on: July 23, 2012, 02:38:14 AM »
Thanks, Dean, yes this engine will use my slave valve arrangement.  Adds as much to the sound as to the operation!
Stew
Thanks Stew, always a compliment to know your watching...
Nick
Thanks, Nick, I've been having a problem of my own this past few days.  The better half has taken over my shop to paint a piece of furniture.  I can't make chips until she has it finished and back in the house.  Hopefully just another day or two!
Chuck
Offline cfellows
« Reply #24 on: July 23, 2012, 02:50:14 AM »
For those of you who may not have seen my opposed 4 cylinder engine, this V8 will use the same valve set up and will be a 4 stroke.
<a href="http://www.youtube.com/watch?v=SYugS_vvPrQ" target="_blank">http://www.youtube.com/watch?v=SYugS_vvPrQ</a>
Chuck
« Last Edit: July 26, 2012, 09:24:16 AM by Bogstandard »
Offline Dean W
« Reply #25 on: July 23, 2012, 05:46:36 AM »
It ought to be quite something to hear running then, Chuck.  I've seen a few of your other engines that use the slave
valve, and it really makes a realistic sounding pop on the exhaust.
Dean
Shop Projects:
Offline cfellows
« Reply #26 on: July 25, 2012, 04:18:38 AM »
I messed up one of the connecting rods trying to make them prettier, so I decided to remake all of them.  Tonight I was drilling the pilot holes for the rod cap screws and broke my only 3/64" bit.  Had to order some new ones so the project is on the shelf for a few days.
In the meantime, I'm working on my own design for a model 2-stroke horizontal oil field engine similar to the Bessemer.  Current plan is for a 1.25" bore, 1.75" stroke, 9" flywheels and hot tube ignition.  If I can't get the hot tube ignition to work, I'll fall back on spark ignition.
Chuck
Offline Dave G
  • Ohio
« Reply #27 on: July 25, 2012, 01:33:35 PM »
Really enjoying your build Chuck. I like your designs a lot, Dave
« Reply #28 on: July 25, 2012, 06:35:45 PM »
Hi Chuck
Very happy that I can continue following your build here.
Offline swilliams
  • Canberra Australia
« Reply #29 on: July 26, 2012, 09:02:56 AM »
Checking in late, but I'm here for the ride now Chuck
