Author Topic: Compressed Air V8 Engine  (Read 70357 times)
Offline cfellows
Re: Compressed Air V8 Engine
« Reply #120 on: August 21, 2012, 12:09:49 AM »
Thanks, Don.  I run the drill bit at the highest speed my drillpress will go which is probably around 3,000 RPM.  I do also go slow.  The only place there's any burrs is on the inside of the steel valve tube.  I just ran the 1/8" bit back up there to clean them out.  I didn't have any problem removing the valve tube after drilling the radial holes in it.  I did mount it in my lathe and smooth it down some with 600 grit wet or dry sand paper but that was it.
I still have some work to do on it.  I'm using a borrowed flywheel for now and plan to make propeller out of steel as a permanent addition.  I also need to make a stand for it and mess with the timing some.  I've got the timing set backward so the engine is running in reverse, but that's easy enough to remedy.
Chuck
Offline cfellows
« Reply #121 on: August 21, 2012, 12:28:49 AM »
Here's the video...  Couldn't be more pleased with the way it runs.  Do wish it was a little louder on the exhaust note.
http://www.youtube.com/watch?v=f0VIV4CVl-U&feature=youtu.be
Chuck
« Reply #122 on: August 21, 2012, 01:06:39 AM »
Woooo! Love that sound, that is awesome Chuck. I like......
Offline rleete
  • Rochester, NY USA
« Reply #123 on: August 21, 2012, 01:15:20 AM »
Surprised it wouldn't run with the smaller flywheel.  I like the look of the one you made.
« Reply #124 on: August 21, 2012, 01:34:17 AM »
Sounds Great Chuck!   Love the sound!    I think it sounds like a Jenny....so a 4 blade old time prop sounds great!
Offline Maryak
« Reply #125 on: August 21, 2012, 01:49:32 AM »
Beautiful job Chuck,
Best Regards
Offline swilliams
  • Canberra Australia
« Reply #126 on: August 21, 2012, 02:30:00 AM »
Excellent Chuck, really well done :NotWorthy:  :pinkelephant: :pinkelephant: :pinkelephant:
« Reply #127 on: August 21, 2012, 02:51:29 AM »
Wow! Excellent Chuck.
I've been waiting all evening to see the video.
Love that low idle.
Offline rleete
  • Rochester, NY USA
« Reply #128 on: August 21, 2012, 02:53:45 AM »
Any possibility you could open up the exhaust ports a little?  That might make it louder.
Offline ColH
  • Geelong, Victoria, Australia
« Reply #129 on: August 21, 2012, 03:58:34 AM »
Hi Chuck
First thing I have been doing every day is to check to see if you have the engine running.
Today was the day.   :whoohoo:
Congratulation on a great build, looks and sounds great.  :NotWorthy:
Col
ColH
« Reply #130 on: August 21, 2012, 07:44:56 AM »
Congratulationa Chuck for another well running engine  :ThumbsUp: :whoohoo: :whoohoo:
Offline ozzie46
« Reply #131 on: August 21, 2012, 12:05:58 PM »
  Cogratulations Chuck another well done Job. Love the sound.
Offline sbwhart
  • Live Long and Prosper
« Reply #132 on: August 21, 2012, 02:10:42 PM »
 :pinkelephant: :pinkelephant: :pinkelephant: :pinkelephant: :pinkelephant: :pinkelephant: :pinkelephant:
Well done Chuck I realy like that engine.
What a great runner
Stew
Offline ironman123
« Reply #133 on: August 21, 2012, 02:16:42 PM »
Good job Chuck. :cheers:  Another feather in your hat. (we have no karma).  Ready for a V8 IC engine yet?
This has been a very good build.  Thanks,
Ray
Ray
Central Texas
Offline Dan Rowe
  • Dripping Springs TX USA
« Reply #134 on: August 21, 2012, 02:23:42 PM »
Chuck,
Thanks for the well written thread on this engine. A good looking engine and a good runner. :cheers:
Dan
ShaylocoDan
