Author Topic: Huff & Puff  (Read 5216 times)
Offline Doc
  • USA ND
Re: Huff & Puff
« Reply #15 on: April 04, 2019, 10:56:39 PM »
Ok didn't get a whole lot done.
I squared up 2 blocks and drilled the connecting rod hole.
From there I put it in a 4 jaw on the lathe and turned up the little boss.
Then went back to the mill drilled the 2 0-80 screw clearance holes and proceeded to mill the block to what you see now.
What is left is the crank hole, radius's and general clean up.
Hope to get them done before the weather gets to nice to stay indoors  ;)
Been trying to take pic along with video when I remember.
Re: Huff & Puff
« Reply #16 on: April 05, 2019, 01:50:41 AM »
Coming along well Doc. I am fascinated by this one.
Re: Huff & Puff
« Reply #17 on: April 05, 2019, 05:00:09 PM »
Excellent progress  :ThumbsUp:  :ThumbsUp:  :wine1:
I think I will have ago at one however I will have to convert it to metric  ::) Marv's picture shows a square cylinder is this a different engine or just modified for easier manufacture?
Re: Huff & Puff
« Reply #18 on: April 05, 2019, 05:35:46 PM »
The latter.
Offline Doc
  • USA ND
Re: Huff & Puff
« Reply #19 on: April 05, 2019, 09:52:44 PM »
Ok finished up the frame or base still needs some hand work though.
Got the flywheels also done.
Then I got distracted and played with my V-8 engines a bit. LOL
Re: Huff & Puff
« Reply #20 on: April 05, 2019, 10:37:34 PM »
Nice progress Doc. Looks like the cylinder is facing the wrong way though unless you are modifying the design. Going to have to build one of these when time allows, cute little buggers.
Offline Doc
  • USA ND
Re: Huff & Puff
« Reply #21 on: April 05, 2019, 10:40:47 PM »
No not modifying just wasn't paying attention LOL
It can be mounted actually either way.
Re: Huff & Puff
« Reply #22 on: April 06, 2019, 08:59:26 PM »
Hi Doc,
I'm building a "Tiny' version of the Huff and Puff. For the piston/piston rod part I made the piston a screw on piece. The reason being, where the rod connects to the connecting rod it's a round cross section and I wanted to make it square. Doing it this way won't allow the rod to go through the hole in the base so I threaded the end, screwed the piston on then turned the piston to size with it mounted. To assemble it I stick the rod through the base, tighten the piston then mount the cylinder.
You might have a look at modifying that part.
Re: Huff & Puff
« Reply #23 on: April 06, 2019, 09:30:18 PM »
Hi Doc,
The Tiny version is so your shop elves can use it?   :Lol:
Offline Doc
  • USA ND
Re: Huff & Puff
« Reply #24 on: April 07, 2019, 12:01:54 AM »
Well got a little done today between going and getting my pepper seeds and tomato seeds and starting soil. Tomorrow I plan on getting them planted in the starting tray.
  So anyway I did get the crank done
also the slide valve and piston.
Re: Huff & Puff
« Reply #25 on: April 07, 2019, 12:38:20 AM »
The dime and dollar show the size well Doc. A small thing it is too. Nice progress.
Re: Huff & Puff
« Reply #26 on: April 07, 2019, 09:23:19 AM »
Hello Doc,
What Bill stated. And cool :ThumbsUp:
Re: Huff & Puff
« Reply #27 on: April 11, 2019, 07:18:26 AM »
Runs well DOC
Looking great, but not what I was expecting! To me huff and puff is a technique..................................
You never heard of the "Big Bad Wolf" ?  ;)
Re: Huff & Puff
« Reply #28 on: April 11, 2019, 02:25:17 PM »
Well done Doc :ThumbsUp: Going to have to make one of these for myself now :)
Re: Huff & Puff
« Reply #29 on: April 12, 2019, 07:08:48 AM »
You could use your fuel tank as a vapour one. It should work fine like that, the incoming air makes the fuel bubble and the outlet draws off the air/vapour mix.
