Author Topic: My scaled down version of the steam traction engine "Minnie"  (Read 2933 times)
Offline Zephyrin
  • near Paris, France
« on: March 13, 2019, 11:26:42 AM »
I think I've already mentioned the misfortune that happened to my little steam tractor...
Made in 2001, this small model is at 1/19 scale, a reduced down version of  “Minnie”, from the Len Mason’s book. Hence my farm traction engine is pretty small, and was built on the small Emco Unimat SL1 lathe. The rear wheels, with a diameter of 100mm, were the maximum for this little lathe, with a riser under the headstock of course!
But unfortunately, my "home-made" wheel foundries made of unknown alloys have not withstood the passage of years, because of the "Zinkpest", in a few years the wheels became swollen and disintegrated then fallen to bits!
I don’t mix anymore recycled metals for casting now…
I have just finished the overhaul: mainly a front wheel and a rear wheel completely redone;
I first machined rear and front wheel rims from good quality aluminium, and recycled the old brass parts of the hubs, and the steel spokes and rim irons (strakes ?), in good condition.
Then spokes were screwed on the hub and riveted on the rim. The 2 rows of spokes on the rear wheel were pretty tricky to rivet, as the visible part of the rivet head is the crushed one…
This tractor is now in good shape and runs very well with a small air compressor.
In accordance with the prototype, the absence of differential gears on the rear wheels makes the turns difficult, as well as the gear shifting without synchromesh, which makes the gears squeak a little...
The steam test will follow, as I have to fix first the broken water level and to change the butane filling valve.
https://photos.app.goo.gl/jAunaSNrpXePn9zT8
Some pictures of this repair:
Re: My scaled down version of the steam traction engine "Minnie"
« Reply #1 on: March 13, 2019, 12:39:39 PM »
Beautiful job on the mini Minnie. Excellent rebuild on the wheels.
« Reply #2 on: March 13, 2019, 01:46:00 PM »
Great to see the little Minnie restored to her former glory. Very nicely done on the wheels too!
Offline Kim
« Reply #3 on: March 13, 2019, 03:41:32 PM »
Very nice little traction engine!  Those old wheels do look like they have seen better days.  Nice rebuild on them!
And thanks for showing us your riveting tools.  I enjoy seeing how people do that.  I struggled for some time to get my rivets to look tolerable.  You'res look great!
« Reply #4 on: March 13, 2019, 05:07:23 PM »
Hello Zephyrin,
That is so cool watching that little dude run over everything, beautiful job. :ThumbsUp:
Have a great day,
« Reply #5 on: March 13, 2019, 05:10:50 PM »
Splendid and so small  :praise2:  :praise2: Awaiting the live steam video  :ThumbsUp:  :ThumbsUp:  :wine1:
Offline scc
  • Lancashire, UK
« Reply #6 on: March 13, 2019, 05:14:20 PM »
Proper Job!            Terry
Offline yogi
  • Duncannon, PA USA
    • Yogi's Workshop
« Reply #7 on: March 13, 2019, 07:58:48 PM »
Beautiful little engine!  :ThumbsUp: :ThumbsUp: :ThumbsUp:
 :popcorn: :popcorn: :popcorn:
« Reply #8 on: March 13, 2019, 10:00:29 PM »
Great rebuild of a nice model - glad to see that you got it running again  :praise2:
ChuckKey
« Reply #9 on: March 14, 2019, 01:53:27 AM »
A super little engine. But it cruel of you to engage gears with the engine running. The "Modern Manual For Drivers of Steam Road Vehicles' contains a photo
of a full size engine upside down at the bottom of an embankment. The caption says "Do not change gear on the move!"
Offline Zephyrin
« Reply #10 on: March 14, 2019, 08:01:25 AM »
Thanks for the comments, very appreciated!
As regards the rivets (1mm dia copper rivets with 1.6mm head), the riveting of the strakes on the rim was fast and easy with a rivet squeezer I did last year, the outside part being filed flush after. On the opposite, it takes ages to rivet spokes on the rim as my rivet squeezer was much too large to enter between spokes !
I did not show the second part of the riveting tool, on the underside, where the rivet head sat. It is a sort of anvil made in a plain steel block with a half-round hollow of the same size of the rivet head (with the dremel). the shape of this tool allows to reach recessed parts and is steadily fixed on the base !
once the rivet has entered (from underside !) through holes in the spoke and rim and its head is well positioned on this bucking tool (whew !) and the job stable on it, forming the head on the front face is easy with the 3 riveting tools shown.
I fully agree with that, I don't get how to change gears without clutch !
I have to stop the engine before, I'll try do that next time.
Similar problems holds true for driving in the absence differential gears on the rear wheels, simply 2 pins to engage or not in the hub of the rear wheels, to facilitate turns...not that easy to master.
Offline MJM460
« Reply #11 on: March 14, 2019, 11:02:45 AM »
Hi Zephryn, what a beautiful little traction engine, and running so well.  Looking forward now to seeing it on steam.
It was a pity about the original wheels, but I expect that is part of the learning when you start exploring castings.  I have heard of those effects of zinc in the mix, but would not have anticipated it to be so dramatic.  You have made beautiful replacements.
Offline Zephyrin
« Reply #12 on: March 15, 2019, 09:23:56 AM »
Thanks MJM...
Wheels were changed into dust in 8-10 years.
Yes it was my first castings, and no help from forum when I built this engine...
The amount of knowledge we can gather over here is amazing !
I don't need an air compressor, as I simply pull the engine backwards to see it running forwards...
https://photos.app.goo.gl/nVw8Xsdp6TZxKa6V6
I did a short steam test, inside the house, rather hectic, the tractor runs much too fast and leaves oily tracks all over !
It is very hard to reduce the flame, as I can't see under the boiler, and I burn my fingers.
I needs practice before I can shoot a video, outside.
Offline Zephyrin
« Reply #13 on: March 19, 2019, 10:35:26 AM »
I have repaired everything, and my small tractor now runs well on steam, but is difficult to control, the steering is difficult on my small terrace, except to make small boring circles;
He's been out in the plant beds a little bit more than a few times !
I think it's just too fast; and adjusting the burner while it's running is difficult without seeing the flames, even with a small mirror!
The cable unwound from the drum and twisted around the rear wheel, blocking the tractor cleanly. And I lost the little lanterns in the garden, but found them thanks to the videos, as I saw where they were lost !
In short, not everything is yet under total control, or nothing is controlled, but I'm quite happy with it.
« Last Edit: March 19, 2019, 06:19:20 PM by Zephyrin »
« Reply #14 on: March 19, 2019, 11:20:20 AM »
Hello Zephyrin,
What a wonderful job you have done with this Traction Engine and the video is so entertaining to watch. You must be very pleased.
Have a great day,
