Author Topic: Going over to the dark (CNC) side!  (Read 56822 times)
« on: February 20, 2019, 02:20:51 PM »
This turned up earlier today
And one of these KX-3 machines was inside
So it looks like I'm going to have to work out what it does. Where are the handwheels :headscratch:
Not been a bad week for packages as these turned up earlier, now that's what I call a generous chucking spigot :)
« Last Edit: March 03, 2019, 08:36:56 AM by Jasonb »
Online steamer
Re: Going over to the dark side!
« Reply #1 on: February 20, 2019, 02:45:57 PM »
Do let us know about the KS3
« Reply #2 on: February 20, 2019, 03:00:37 PM »
Where's that Darth Vader emoji when you need it  :lolb:
Offline kuhncw
« Reply #3 on: February 20, 2019, 06:04:56 PM »
Nothing dark about it.
Enjoy the CNC!
Chuck
« Reply #4 on: February 20, 2019, 06:34:19 PM »
Just need a bigger workshop so you can fit it in  ::)
« Reply #5 on: February 20, 2019, 09:12:28 PM »
Google  "KS-3 machine" did not give any clues and adding CNC to the search was no help either  :headscratch:
Will you elaborate with more info later Jason ?
« Reply #6 on: February 20, 2019, 09:25:02 PM »
Typo - its a Sieg KX-3
« Reply #7 on: February 20, 2019, 10:09:25 PM »
Rather than going to the dark side you have seen the light.   :cheers:
« Reply #8 on: February 28, 2019, 09:05:06 AM »
I got my Mack3 licence yesterday which meant I could run more than 500 lines of code so had a bit more of a play. The Sieg logo comes as a demo code so I ran that first.
This machine was a customer return and was known to have issues with the Z axis having been crashed into the top of the column and I was having problems getting the heights right so pulled all the electronics off the back (8 screws) so I could have a better look at the mechanicals, found something loose and tightened that up.  I ran this code about 8 times last night and could not get depths right - (tool finished up higher than when it started) before tightening the loose part. Have run it 3 times this morning and so far all seems OK, will run it a few more times later..
« Reply #9 on: February 28, 2019, 11:21:52 AM »
<a href="https://www.youtube.com/watch?v=KdVKuZ7b9XI" target="_blank">http://www.youtube.com/watch?v=KdVKuZ7b9XI</a>
Offline jadge
  • Cambridge, UK
« Reply #10 on: February 28, 2019, 12:37:42 PM »
Never thought I'd see the day..................  :o
Andrew
« Reply #11 on: March 01, 2019, 05:55:38 PM »
Looks like my days of buying cast iron flywheels could be coming to an end if I can produce ones like this in metal, notice that it even has the spoke halves out of line just like the real thing :shrug:
« Reply #12 on: March 01, 2019, 06:30:33 PM »
What is the material Jason? Some type of plastic I assume, but looks fuzzy in places so wasn't sure.
« Reply #13 on: March 01, 2019, 07:37:19 PM »
With fuzzies like that, it's most likely some flavor of that brown stuff that Jo hates.
« Reply #14 on: March 01, 2019, 07:50:55 PM »
It's just some offcuts of UPVC facia board which has a dense foam type core, not the best for getting a good surface on but ideal for getting the hang of using the machine as it's a bit more forgiving if I get feed rates wrong. Having said that it's happy with me cutting it at 5000rpm and 1500mm/min (60"/min) feed with a 3mm 3-flute cutter.
It does have a black woodgrain finish on one side ;)
