Engines > From Kits/Castings
Lincoln Cross Compound Mill Engine
<< < (2/14) > >>
Kim:
Sounds like another fun ride!  You'll all have to scoot over and make room for me too :)  :popcorn:
Roger B:
Glad you are under way again  :) Is that the table from the previous plan?
J.L.:
Thanks guys.
It's good to be back in the saddle.
Roger, you've got a keen eye. Yes, that's the ange iron table that was going to be part of the colliery. I cut six inches off of it to suit the new diorama format. Phoenix rose from the ashes,
J.L.:
The top of all ll industrial windows seem to be either arched or rounded , I would think strength to be the determining factor.
To obtain a nice smooth arch over the window openings I drilled a pivot hole in a flat plastic bar and fastened it to a trim router.  The radius was four inches.
pgp001:
I have a set of castings stashed away for this engine as well.
Do you need any of the drawings or the build articles, I have them all as PDF files.
Phil
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
