Author Topic: Looking for small water pump plans.  (Read 1758 times)
Re: Looking for small water pump plans.
« Reply #15 on: February 05, 2019, 08:45:51 PM »
Hi Gas_mantle
This might be of some use to you, its a hand pump I built a while back and has been very reliable. I have recently used it to hydraulic test my loco boiler
http://www.modelenginemaker.com/index.php/topic,336.msg2089.html#msg2089
Rich
Rich, thats a slick setup with the o-rings, had not seen that before, seems like it should hold better than the steel ball method on seats that are not perfect. Interesting!
Offline Firebird
  • East Midlands UK
« Reply #16 on: February 05, 2019, 09:53:05 PM »
Hi
Yes its a lot easier to get the O rings to seal than balls. It will pump a 100psi no problem and hold without dropping pressure
Rich
Online mnay
« Reply #17 on: February 19, 2019, 07:34:11 PM »
the o rings are a great idea!!!!!
I have trouble with the balls sealing, especially after they sit unused for a month or two.
