Author Topic: Little Demon V8  (Read 1664 times)
Offline Spanner
  • Jr. member
Little Demon V8
« on: February 02, 2019, 02:28:04 AM »
Hullo members, can anyone help with cad drawing showing lobe degrees ect or G code for Little Demon V8 Camshaft thank you Peter
Re: Little Demon V8
« Reply #1 on: February 02, 2019, 02:38:48 AM »
Hi Spanner!   Welcome to the forum!    I'm sure Steve Huck will along shortly will be glad to help you out, as he was the designer of the Demon.  Meanwhile, pop over to the "introduce yourself" section and consider putting up a post telling us about yourself.   We'll be glad to help
Dave  (steamer)
Moderator
Offline stevehuckss396
  • Sterling Heights, MI USA
Re: Little Demon V8
« Reply #2 on: February 02, 2019, 03:24:55 AM »
Hello Peter!
Lobe degree is 280 duration (140 cam degrees) with 110 degrees separation and .070 lift and a flank radius of .696. Cant help with Gcode as I cut mine manually.
