Jim, Dave,Will you be able to make a 3D print of your casting pattern with all the required draft angles and a sufficiently smooth surface to allow them to be withdrawn from the sand mould box?Just thinking out loudMike
I have 3d printed casting patterns. I start by drawing the pattern in Fusion 360. I can add draft if required and even split patters or make multi-piece patterns. I have not cast any yet as health problems and cold weather have kept my foundry in storage.So far, I have printed parts for a vertical and a horizontal oscillating steam engine, flywheels, and the body of a lathe slotting tool that was featured in the first issue of "Model Engineer's Workshop". Rob Wilson(I think) did a build log or a magazine article of the same slotter with the body cast in brass or bronze.I was redrawing the Gingery Shaper to make the patterns also, but I currently have a rather poor set of wooden patterns for it.Lots of folks doing 'lost pla' casting but I'd rather keep the pattern and be able to reuse it. The patterns don't have to be printed with high infill either, just enough to withstand tamping of the sand in the mold.
USPS just rolled up and delivered my printer Ill more than likely be up all night now reading and assembling the beast. Assembling and fine tuning will be the easy part. Learning Fusion 360 and all that is going to be the REAL challenge. BC1Jim
