Author Topic: Stuart No 1  (Read 31735 times)
Re: Stuart No 1
« Reply #195 on: February 19, 2019, 05:25:00 PM »
The problem with the 'silent' ones they have very little output volume. I was thinking belt driven this time  :noidea:
This one should be able to run any of my engines up to the Commander which has a 75mm bore  :thinking:
Re: Stuart No 1
« Reply #196 on: February 19, 2019, 05:27:58 PM »
So where's the video of the Vrooom  ;)
Re: Stuart No 1
« Reply #197 on: February 19, 2019, 05:36:40 PM »
I've got a 5 hp, 60 gallon tank one at the shop. Belt driven but still noisy. Having it in that closet area helps, but it's still loud. I will use the quiet one for most things, but yeah...a 75mm bore will take some volume!!
Re: Stuart No 1
« Reply #198 on: February 20, 2019, 02:15:40 AM »
The tree cutting boys who borrowed it have jammed the regulator valve fully down and it is no longer adjustable :Mad: the result is the No 1 tries to have your fingers off  :paranoia:
 :o. Well, at least you know it runs  :embarassed:
Re: Stuart No 1
« Reply #199 on: February 20, 2019, 02:42:28 AM »
Well, I guess it's a good thing you're an engineer, Jo. That means you can fix it!
Just what you need to keep you busy..... :paranoia:
Re: Stuart No 1
« Reply #200 on: February 20, 2019, 07:40:24 AM »
Its a time problem Pete: When you are retired you just don't have the spare time you had when you were at work   :embarassed:
Need to find some time to choose a new compressor and check it will fit somewhere  :thinking:
ChuckKey
Re: Stuart No 1
« Reply #201 on: February 20, 2019, 09:40:44 AM »
Do you (or the elephant) have a set of Stuart compressor castings?
Offline Gas_mantle
  • North Yorks - UK.
    • My Youtube channel
Re: Stuart No 1
« Reply #202 on: February 20, 2019, 09:50:29 AM »
Can't you rig up something as a temporary measure just so we can see the engine running  :)
Re: Stuart No 1
« Reply #203 on: February 20, 2019, 01:30:48 PM »
The engine is back in pieces.... a compressor valve has been ordered.
The first video I did I forgot to put on the valve guide  :facepalm:
Still thinking about a new compressor: hydrovanes look nice.. except the price  :paranoia:
Re: Stuart No 1
« Reply #204 on: February 20, 2019, 01:38:17 PM »
Ain't that the truth!!
Re: Stuart No 1
« Reply #205 on: February 20, 2019, 03:21:13 PM »
Can someone let me know how to rotate videos... I am sure UTube used to do in but I can't find it  :facepalm:
<a href="https://www.youtube.com/watch?v=Dz23z1jpf98" target="_blank">http://www.youtube.com/watch?v=Dz23z1jpf98</a>
Re: Stuart No 1
« Reply #206 on: February 20, 2019, 03:23:51 PM »
Excellent  :praise2:  :praise2: I just turned my laptop on its end, no problem  :)
Re: Stuart No 1
« Reply #207 on: February 20, 2019, 03:26:38 PM »
Hold your phone the right way to start with.
Runs well
Re: Stuart No 1
« Reply #208 on: February 20, 2019, 03:39:02 PM »
My mobile phone doesn't take photographs  :hellno:
I can fit a 100ltrs tank compressor inside the main garage or a 150ltrs one if I put it outside. This one looks interesting:
https://www.ebay.co.uk/itm/100-Litre-Air-Compressor-14-6CFM-3HP-100L-Belt-Drive-Twin-cylinder/352371734205?hash=item520afdf6bd:g:xjgAAOSwVoNcMtT7
 :thinking:
Re: Stuart No 1
« Reply #209 on: February 20, 2019, 03:44:19 PM »
I thought you may have used it to take the video as that is often what caused them to be rotated.
On youtube goto my channel, then bottom left go back to the old classic view, select videos and it should list yours down the page with EDIT and a downwards arrow next to that. Click the arrow and select enhancements from that list, the screen that then comes up will have rotate options.
