The tree cutting boys who borrow5ed it have jammed the regulator valve fully down and it is no longer adjustable the result is the No 1 tries to have your fingers off Jo
What sort of regulator ??The 'one in / one out ' sort or the type with 3 ports & elec. contacts therein ?????
Quote from: Bluechip on February 19, 2019, 03:50:14 PMWhat sort of regulator ??The 'one in / one out ' sort or the type with 3 ports & elec. contacts therein ?????The one which has 120 PSI in and lets you wind the output down to 0 PSI, rather than straight through 120 PSI Its not safe running a steam engine at 120 PSI Jo
Quote from: Jo on February 19, 2019, 04:18:17 PMQuote from: Bluechip on February 19, 2019, 03:50:14 PMWhat sort of regulator ??The 'one in / one out ' sort or the type with 3 ports & elec. contacts therein ?????The one which has 120 PSI in and lets you wind the output down to 0 PSI, rather than straight through 120 PSI Its not safe running a steam engine at 120 PSI JoStrapped to the bench, and with 160 psi air, the engine in my boat sounds like a Japanese motorcycle in full song spinning about 2000 rpm. LOL Ask me how I know this?
Beer may have been involved..... What happens in the machine shop at work...stays in the machine shop at work....just sayin.
Put a kink in the hose, that will soon slow it down
I was thinking of a new compressor I just have to decide which one Jo
