Author Topic: Stuart No 1  (Read 32127 times)
Re: Stuart No 1
« Reply #90 on: February 02, 2019, 04:33:22 PM »
Thanks Bill,
I wouldn't worry about 3 unfinished projects - it just means you have a choice of what you fancy working on.   :cartwheel:
 :o I said the work word  :lolb: Don't you love its meaning once you are retired... Its over six months now  :mischief:
Re: Stuart No 1
« Reply #91 on: February 02, 2019, 04:50:47 PM »
Indeed I do Jo. And every day a Saturday too!!  :cartwheel:
« Last Edit: February 03, 2019, 01:02:38 PM by b.lindsey »
Re: Stuart No 1
« Reply #92 on: February 03, 2019, 09:07:25 AM »
Do you still have some material to come off the bottom of the rod as your hole looks a bit high up compared to the drawing which should cure things.
I took 2mm off the end of the rod before assembling it. Its nearly got enough movement  :thinking:
Re: Stuart No 1
« Reply #93 on: February 03, 2019, 04:45:45 PM »
The big end bearings were mounted on the same jig I used to turn the 5A bearings and turned to the same diameter as the end of the rod. Then a bit of fettling/scraping/fitting to get the round and round testing to feel just right  :)
Thankfully I decided to use 5BA studs and nuts on the slide guides as I think 4BA as shown on the later drawings would be too close
Offline Bluechip
  • Derbyshire
Re: Stuart No 1
« Reply #94 on: February 03, 2019, 05:24:54 PM »
Hi Jo
Looking good ..  :ThumbsUp:
However, kindly dab in and get the support bit from the base to the lower cylinder cover sorted ...  :thinking:
Stop this thing going through my fevered little brain ...    :Jester:
<a href="https://www.youtube.com/watch?v=lbnkY1tBvMU" target="_blank">http://www.youtube.com/watch?v=lbnkY1tBvMU</a>
Re: Stuart No 1
« Reply #95 on: February 03, 2019, 06:35:49 PM »
So are we going round and round and up and down (with a driving dog)  :)  :wine1:
Re: Stuart No 1
« Reply #96 on: February 03, 2019, 09:08:14 PM »
Yep :D
But there is no hopping around on one leg :hellno:
Re: Stuart No 1
« Reply #97 on: February 03, 2019, 09:24:33 PM »
Some more pics from Eric. He is taking a different tac on his build and has been doing the steam chest  :thinking:.
Re: Stuart No 1
« Reply #98 on: February 04, 2019, 04:40:55 PM »
Not a lot to show today  :disappointed:
I've pinned the crank, cleaned up/shaped the bearing caps and made some oil pots to enable round and round testing to progress.
Hopefully achieve a bit more tomorrow  :-[
Re: Stuart No 1
« Reply #99 on: February 04, 2019, 11:24:28 PM »
Nice job on the pinning Jo. They don't show at all!!
Re: Stuart No 1
« Reply #100 on: February 05, 2019, 12:18:07 AM »
Looking sweet Jo!   that's cruising right along now!    won't be long!
Re: Stuart No 1
« Reply #101 on: February 05, 2019, 04:28:51 PM »
I started the morning by taking the sides of the standard down so that they were level with the guide bars.
To enable advanced round and round testing I decided it was about time to machine the flywheel which of couse was already machined undersized  :( the worse bit being that they did not level up on the inside rim of the flywheel or centre it  :wallbang:  :wallbang:
It was easy enough with a quality three jaw chuck to get it running true again to be able to bore the centre and skim the edge faces. I chose to mount it on an arbour to skim the outside edge. As per the original drawings I chose to add a key in my flywheel so used a broach and before cutting used it to make sure the key followed the line of one of the spokes.
The Flywheel and the standard have been primed up so I couldn't re-assemble the engine so far so I have started on the steam chest by machining the two large faces flat. I can now start working out how much I want to take off of each of the sides, thankfully there is plenty of metal to come off  :)
« Last Edit: February 05, 2019, 05:04:08 PM by Jo »
Re: Stuart No 1
« Reply #102 on: February 05, 2019, 05:52:18 PM »
The flywheel looks to be sorted :ThumbsUp:  :ThumbsUp: How big is it? I am guessing that it is in the Colchester.
Re: Stuart No 1
« Reply #103 on: February 05, 2019, 05:57:50 PM »
I'm not entirely sure Roger  :noidea: , I suspect the inside curve is still going to go wobbly wobbly when it goes round   :-\
Its 180+mm diameter and yes that is Big C doing that bit of the turning  ;)
Re: Stuart No 1
« Reply #104 on: February 06, 2019, 07:56:22 AM »
Best get that new compressor on order as it won't belong before you will be wanting it to go chuff, chuff at the rate you are going :) Lucky that the previous owner had not bored the flywheel as that would more than likely have been off.
PS Don't tell the little fellow but I just bought a set of castings :-X
