Author Topic: Stuart No 1  (Read 31671 times)
Offline Gas_mantle
  • North Yorks - UK.
    • My Youtube channel
Re: Stuart No 1
« Reply #210 on: February 20, 2019, 03:59:04 PM »
Yay, we have a runner thanks  :)
As for the rotating of videos, I think youtube must have altered the software as I also used to be able rotate but no longer have that option.
Offline Bluechip
  • Derbyshire
Re: Stuart No 1
« Reply #211 on: February 20, 2019, 04:00:53 PM »
My mobile phone doesn't take photographs  :hellno:
I can fit a 100ltrs tank compressor inside the main garage or a 150ltrs one if I put it outside. This one looks interesting:
https://www.ebay.co.uk/itm/100-Litre-Air-Compressor-14-6CFM-3HP-100L-Belt-Drive-Twin-cylinder/352371734205?hash=item520afdf6bd:g:xjgAAOSwVoNcMtT7
 :thinking:
How robust is your leccy supply ??  A 3HP motor is pushing a ring main  :thinking:  Usually has to have a 32A socket on a dedicated 30A C curve breaker.
Look at the bottom end of this ad  ... this is the compressor a mate has in his chippy shop for nailers / sanders etc.
14 CFM Piston Displacement  gives  some 2/3rds of that FAD  IIRC
https://www.sgs-engineering.com/sc90b-90-litre-air-compressor-14cfm
« Last Edit: February 20, 2019, 04:06:47 PM by Bluechip »
Re: Stuart No 1
« Reply #212 on: February 20, 2019, 04:02:11 PM »
Go back to the old classic studio rather than the Beta
Re: Stuart No 1
« Reply #213 on: February 20, 2019, 04:10:55 PM »
I have a 45A supply to the three phase transformer, larger supply to the workshop than to the house  :lolb:.
I have found a 'quiet' one for a couple more beer tokens:
https://www.ebay.co.uk/itm/Air-Compressor-100L-3HP-Oil-free-Compressor-Low-noise-Silent-65dB/352437614634?hash=item520eeb382a:g:DKcAAOSwpTBb~8Wt
Offline Gas_mantle
  • North Yorks - UK.
Re: Stuart No 1
« Reply #214 on: February 20, 2019, 04:16:08 PM »
I've tried that but even in Classic mode the rotation option has gone.
Re: Stuart No 1
« Reply #215 on: February 20, 2019, 04:16:46 PM »
Don't think that is a silent as the fridge type compressor ones which are around 40DB and as sound is logarithmic there will be quite a difference but still less that a standard one. Also volume drops so once tank is used up you will be running all the time trying to catch up.
Re: Stuart No 1
« Reply #216 on: February 20, 2019, 04:17:23 PM »
Very nice result Jo, thanks for posting the video!
Re: Stuart No 1
« Reply #217 on: February 20, 2019, 04:24:09 PM »
That last link you posted looks to have heads similar to the California Air Compressor line. With three heads and two pistons per head it should recover pretty quickly and they really are much quieter!!
ChuckKey
Re: Stuart No 1
« Reply #218 on: February 20, 2019, 05:40:21 PM »
This is basically the same thing as your first choice only a bit cheaper:
https://www.amazon.co.uk/Wolf-Dakota-150psi-Cylinder-Compressor/dp/B007VOLOHG/ref=sr_1_1?ie=UTF8&qid=1550684016&sr=8-1&keywords=wolf+dakota+compressor
I bought one a couple of years ago. It is much quiter than the horrid little thing I had before. Does need a 16A plug though.
Re: Stuart No 1
« Reply #219 on: February 20, 2019, 05:46:43 PM »
Shes a runnah!!! :cartwheel: :praise2:
Good job Jo!
Re: Stuart No 1
« Reply #220 on: February 20, 2019, 06:01:17 PM »
Thanks Dave  :)
Ok money spent  :)
Following discussion with my supplier: I have brought the compressor I originally posted the link to. It claims to be able 7dB quieter than the other oil compressors of similar size. It is not as quiet as the diaphragm compressor which I had the sound described as if it was constantly farting in the corner  :facepalm2: and the diaphragms break - there are 6 opportunities to break in that one.
The other advantage of a belted compressor is it can go outside if I can't stand the sound  ::)
Re: Stuart No 1
« Reply #221 on: February 20, 2019, 06:21:59 PM »
Not important since the decision is made but I think you will find that the quiet oilless compressor is not a diaphragm compressor, at least mine isn't.
Re: Stuart No 1
« Reply #222 on: February 20, 2019, 07:15:29 PM »
Many of these are scroll compressors
Re: Stuart No 1
« Reply #223 on: February 20, 2019, 08:05:13 PM »
Nice runner, Jo!
Offline john mills
Re: Stuart No 1
« Reply #224 on: February 20, 2019, 08:44:53 PM »
nice to see it running
