Author Topic: Stuart No 1  (Read 32335 times)
Re: Stuart No 1
« Reply #180 on: February 19, 2019, 03:57:08 PM »
The tree cutting boys who borrow5ed it have jammed the regulator valve fully down and it is no longer adjustable :Mad: the result is the No 1 tries to have your fingers off  :paranoia:
We DID get a VROOM! :lolb:
Re: Stuart No 1
« Reply #181 on: February 19, 2019, 04:18:17 PM »
What sort of regulator ??
The  'one in / one out ' sort or the type with 3 ports & elec. contacts therein ?????
The one which has 120 PSI in and lets you wind the output down to 0 PSI, rather than straight through 120 PSI  :paranoia:
Its not safe running a steam engine at 120 PSI  :hellno:
Re: Stuart No 1
« Reply #182 on: February 19, 2019, 04:21:48 PM »
Strapped to the bench, and with 160 psi air, the engine in my boat sounds like a Japanese  motorcycle in full song spinning about 2000 rpm.   LOL :lolb:  Ask me how I know this?
Re: Stuart No 1
« Reply #183 on: February 19, 2019, 04:27:55 PM »
Sounds like a test preceeded by 'here, hold my beer!"   :Lol:
Re: Stuart No 1
« Reply #184 on: February 19, 2019, 04:29:02 PM »
Beer may have been involved..... :paranoia:
What happens in the machine shop at work...stays in the machine shop at work....just sayin.
Re: Stuart No 1
« Reply #185 on: February 19, 2019, 04:31:30 PM »
All stays in the shop, except for the bits flying through the window....!
Re: Stuart No 1
« Reply #186 on: February 19, 2019, 04:34:38 PM »
Nope   None of that....ran like that for 10 minutes.....that's when the building air compressor got unhappy....   8)
It would have taken your fingers off at the shoulder...... :zap:
Offline Bluechip
  • Derbyshire
Re: Stuart No 1
« Reply #187 on: February 19, 2019, 04:41:58 PM »
Like this:
1/4" BSP in / out  wind the knobby wotsit to desired pressure and then lock with nut underneath ??
Martonair, used to have it on my bead blaster     ;D
PS No, I don't know why the date is crook ....  :headscratch:
« Last Edit: February 19, 2019, 04:49:45 PM by Bluechip »
Re: Stuart No 1
« Reply #188 on: February 19, 2019, 04:44:26 PM »
Put a kink in the hose, that will soon slow it down ;)
Re: Stuart No 1
« Reply #189 on: February 19, 2019, 04:46:02 PM »
Just a ball valve will work fine.
Re: Stuart No 1
« Reply #190 on: February 19, 2019, 04:54:32 PM »
Or better still use the regulator manifold you made earlier
Re: Stuart No 1
« Reply #191 on: February 19, 2019, 04:56:28 PM »
^^^^  there ya go!
Re: Stuart No 1
« Reply #192 on: February 19, 2019, 05:00:36 PM »
I was thinking of a new compressor  ::)
I just have to decide which one  :noidea:
Re: Stuart No 1
« Reply #193 on: February 19, 2019, 05:05:31 PM »
I vote for a quiet one   ;)
Re: Stuart No 1
« Reply #194 on: February 19, 2019, 05:22:29 PM »
That's on my list as well....
