Author Topic: helical gear with cnc  (Read 2375 times)
Offline michelko
« on: January 16, 2019, 09:08:36 AM »
Hi,
after some Research and heavy thinking i was able to adapt the cfellows helical gear tool into my cnc machine.
Beeing a Little lazy i didn┤t want to build the fixture. At first i tryed a 45 ░ helical gear.
I mounted the cnc dividing head under 45 ░ Degree on the table and used a m0,9 involute gear cutter.
After some calculations a made a quick and dirty short program.
at this setup the mill has to move three axes simultanious (x, y a)
Here is a video from machining:
And here is a video testing the gears on my lathe.
came out realy nice.
« Last Edit: January 16, 2019, 09:11:49 AM by michelko »
  • S°ften - Denmark
Re: helical gear with cnc
« Reply #1 on: January 16, 2019, 11:45:22 AM »
That looks nice and easy, but I kind of expect that it took quite some calculations and verification, before these videos  :thinking:
Or did you have a CAM program that took care of that for you ?
Best wishes
« Reply #2 on: January 16, 2019, 12:13:24 PM »
The good news is that each "valley" is machined with a single g-code move, so you just have to determine the cutter and material positions at start and end.  The control synchronizes getting all the axes so that they reach the end at the same time.
It looks as if the axes here are x, z, and a.
My fourth axis is very heavy and setting it at a 45 degree angle would be a hassle.  I'm thinking that a button type cutter would work with the gear blank horizontal in X and tool on top.  Then Z and Y would be constant and I'd just move X and C together.
Offline michelko
« Reply #3 on: January 16, 2019, 01:20:33 PM »
Hi,
the quick and dirty g-Code looks something like this:
g91 g1 x-15 y-15 a -190,98 f30  [syncronized cutting move]
g91 g1x15y15a190,98 f60 [retract]
g91 g0 a-36 (next tooth)
Then copy and paste these lines 9 times and you have the program for an 10 tooth gear
  • S°ften - Denmark
« Reply #4 on: January 16, 2019, 09:42:30 PM »
Thank you Michael
OK this is relative simple - though I have to admit that I haven't used the G91 instruction yet ....
One question from one who haven't made gears yet. If you wanted a 12 tooth gear here, would it just be a-30 in the last line and maybe adjust the depth of cut ?
Offline michelko
« Reply #5 on: January 17, 2019, 03:57:41 PM »
Hi yes the last line is the tooth angle (360 /tooth).
In this case The absolut coordinates are not relevant.
Just touch of and set the machining depth.
Because of the aluminium i used just one pass, steel requires maybee more smaler passes.
« Reply #6 on: January 17, 2019, 06:59:52 PM »
I may be blind, but why/where is the Y axis move in the video?  The spindle must move downward as the cut proceeds.  That's Z on my mill.
Offline michelko
« Reply #7 on: January 17, 2019, 07:57:21 PM »
 :facepalm:
Offcourse you are right. My fault
It moves x,z and a :ThumbsUp:
Y is setup at the beginning as cutting depth and then left steady
Offline kuhncw
« Reply #8 on: January 19, 2019, 09:19:15 PM »
Michael,
Thanks for posting your code.
"g91 g1 x-15 y-15 a -190,98 f30  [syncronized cutting move]
g91 g0 a-36 (next tooth)"
What is the function of the 98, following a-190 and a190 ?
Chuck
« Reply #9 on: January 21, 2019, 06:23:00 AM »
In Europe they use comma instead of period as a decimal point.
Offline michelko
« Reply #10 on: January 21, 2019, 08:46:53 AM »
You are Right. for Linuxcnc it must be something like this
g91 g1 x-15.00 y-15.00 a -189.9 f30
michael
Offline kuhncw
« Reply #11 on: January 21, 2019, 03:49:48 PM »
Thanks for setting me straight.  I keep forgetting about , vs .
Chuck
Offline jadge
  • Cambridge, UK
« Reply #12 on: January 22, 2019, 11:34:50 AM »
I'd be interested to know how the OP got on with feedrates. Any sort of X, Y or Z move is obviously in distance per time, and a pure rotary movement is in degrees per time. As far as I can see a combined linear and rotary movement should be in distance per time, accounting for the longer path due to rotation.
When I cut helical paths, to machine a worm, I had all sorts of issues with the feedrate. My rotary table just ran flat out irrespective of the specified feedrate. This was with a Tormach customised version of Mach3. I wasted a huge amount of time trying different things. In the end I came to the conclusion that this particular feature in Mach3 plain didn't work. I ended up using inverse time feedrates aka G93. For those not familar with G93 the time (in minutes) to do the cut is the inverse of the number. So if the code is G93 0.2 then the cut will take 5 minutes. Oddly, this worked absolutely fine in Mach3. There was a small time error,  few seconds, but it was consistent and fixed.
Andrew
« Reply #13 on: January 22, 2019, 01:38:56 PM »
A CNC control is responsible for ensuring that coordinated axes move to arrive at the end point at the same time and in a linear fashion.  I had read that Mach3 had a problem doing this with a rotary axis unless using inverse time, but I have verified that my PathPilot control does it correctly.  I'm not sure how to calculate feed rates, but I'd probably treat a round cutter like a saw.
Offline jadge
  • Cambridge, UK
« Reply #14 on: January 22, 2019, 04:01:56 PM »
Good to know that PathPilot works properly with 4-axis moves. I've upgraded, but haven't tried it with continuous 4-axis moves, just indexing which works fine. In my hiccups with Mach3 Tormach effectively stated that the 4-axis moves, and diameter/radius compensation boxes (whatever they are), didn't work.
I'm not sure I understand the comment about feedrates? For a helical cut I simply unwrap the helix mathematically to get the total length of cut and then apply normal calculations as for a simple linear cut.
Andrew
