Author Topic: Edwards 5 Cylinders.  (Read 27279 times)
Online Roger B
Re: Edwards 5 Cylinders.
« Reply #75 on: April 05, 2019, 05:03:02 PM »
I like the valve  :ThumbsUp:  :ThumbsUp: Why the inch ruler?
Offline petertha
« Reply #76 on: April 05, 2019, 07:14:09 PM »
Nice. What material for the valve?
Offline glorfindel
« Reply #77 on: April 06, 2019, 11:18:07 PM »
I like the valve    Why the inch ruler?
I always work in imperial unit.
Envoyé de mon SM-G965W en utilisant Tapatalk
Offline glorfindel
« Reply #78 on: April 06, 2019, 11:19:24 PM »
Stainless 305.
Offline glorfindel
« Reply #79 on: April 18, 2019, 04:48:59 PM »
I redesigned the push rod, the cam follower and the rocker screw. The plan call for a 0.080" diameter socket. We dont have 0.080" ball nose. So i did it with a .125" socket to be able to use a .125" ball nose.
New vs old
« Reply #80 on: April 18, 2019, 08:47:24 PM »
Other checking that you do not create other issues, like interference, I can't think of any negatives (except for those that insist on perfect copy of the original).
Offline glorfindel
« Reply #81 on: April 18, 2019, 10:19:11 PM »
I'm using CatiV5, i can simulate all the movements, that's the fun part of desiging stuff in 3d ;-)
I hope i didnt miss something.
I'm not a purist, i already made changes and i will make way more in the V2.
Offline Mike R
  • Ottawa, ON
« Reply #82 on: April 19, 2019, 02:54:11 AM »
I don't see any issue with changing dimensions, as long as it all fits together at the end.  Don't get caught making that one little change and then not being able to assemble the parts!
(following along - I love radial engines....)
Offline petertha
« Reply #83 on: April 19, 2019, 04:42:52 AM »
Offline petertha
« Reply #84 on: April 19, 2019, 04:45:21 AM »
I didnt refer to the Edwards plans but any particular reason you have a female socket on one lifter & male ball on the other. Or is this original design vs your modification?
What keeps the lifter aligned on the flat face so they don't rotate?
Offline glorfindel
« Reply #85 on: April 19, 2019, 01:51:33 PM »
It's old vs new design, on the cam side.
The rocker side is ending with a 0.115" sphere.
For the rocker part. I'will make a one piece 4-40 threated socket screw or an adaptator that i will screw on the 4-40 rocker screw.
I didnt finished the 3d model yet. I'll post pics next week. That will be clearer than my explaination :-)
Offline glorfindel
« Reply #86 on: April 24, 2019, 10:18:25 PM »
Did the first side of the head.
Offline glorfindel
« Reply #87 on: April 26, 2019, 04:58:29 AM »
Guys, did you check the pics??
The bolt pattern is off lol!! I didnt noticed it t'ill this morning.
I putted a wrong number in tha cnc ;-)
« Reply #88 on: April 26, 2019, 10:16:27 AM »
Been there - done that ...!.... though not with a bolt circle .... more like a move that broke the tool  :cussing:
Offline Stuart
  • Tilchestune UK
« Reply #89 on: April 26, 2019, 10:50:47 AM »
Ditto
But mine was the probe off the 3D taster got the wrong axis set on the pendant twirled the wheel ping
Shame about the bolt circle just smile and reprogram ,press start and all will be good
