Author Topic: Edwards 5 Cylinders.  (Read 11257 times)
Offline glorfindel
Re: Edwards 5 Cylinders.
« Reply #15 on: January 16, 2019, 09:54:27 PM »
Newer seen the drawings so I'm only guessing here .... is there a vane pump on the inside ?
Nope.
But i think i got the answer. Look at the drawing, there is 2 intakes tube that are higher on the manifold ( to prevent hydrolock of bottom cylinders ) , i guess the offset in the cover is for centering the carbs vs the intakes tubes.
Envoyé de mon SM-G965W en utilisant Tapatalk
Offline petertha
« Reply #16 on: January 17, 2019, 05:35:21 AM »
I think you might be right there. I always wondered about that. Without the elevated tube ends in the manifold, any fuel flooding from the carb would drain directly down the lower induction tubes & sit in the head ports until valve opened & then bad things happen. Makes sense.
On my radial, different induction path as mentioned previously. But that makes my liquid accumulation sump the master rod groove in the crankcase. At least only fuel vapor can go to heads, but I am making provisions for a drain plug in the bottom of crankcase.
Anyway good observation.
Offline glorfindel
« Reply #17 on: January 18, 2019, 09:11:47 PM »
New parts.
« Reply #18 on: January 19, 2019, 02:23:29 AM »
I have started following along. Amazing how much you miss when you travel. I have seen other builds on the Edwards radial 5 but I think they were on different forums. I have 2 radials on my bucket list the Kinner K5 in SIC and Jemma also in SIC, someday.
Offline glorfindel
« Reply #19 on: January 21, 2019, 10:52:16 PM »
Did the pistons today. I changed the ring groove to 1mm( 0.039") instead of 0.0325" because i already had the 1mm grooving tool, so i adjusted the pattern.
I will make the ring 0.008" thicker.
« Reply #20 on: January 22, 2019, 12:16:59 AM »
Nice looking piston!    What lathe is that?
Offline glorfindel
« Reply #21 on: January 22, 2019, 12:27:20 AM »
DMG 1250CTX mill/turn. A nice toy :-)
« Reply #22 on: January 22, 2019, 12:32:51 AM »
LOL   :lolb:   Yeah Mori's usually are.    Sweet!
Offline glorfindel
« Reply #23 on: January 24, 2019, 01:58:53 AM »
Honned the cylinders a little bit.
Offline glorfindel
« Reply #24 on: January 25, 2019, 02:30:54 PM »
We got a little problem with the 1250 post-processor, so i decided to change the rocker shape to make it easier to program directly on the cnc.
I'm little bit lighter, same strengh.
Will try to cnc it this afternoon.
Offline glorfindel
« Reply #25 on: January 28, 2019, 09:33:15 PM »
Did the rockers today.
Offline dieselpilot
« Reply #26 on: January 29, 2019, 02:32:25 PM »
Nice!  DMG 1250CTX :P
Offline yogi
  • Duncannon, PA USA
    • Yogi's Workshop
« Reply #27 on: January 30, 2019, 06:51:56 AM »
Very nice!!!  :ThumbsUp: :ThumbsUp: :ThumbsUp:
Keep the pictures coming...  :popcorn: :popcorn: :popcorn:
Offline glorfindel
« Reply #28 on: January 30, 2019, 05:09:43 PM »
Done.
Offline glorfindel
« Reply #29 on: February 06, 2019, 03:32:17 PM »
Will do this one today
