Author Topic: AOG’s PMR BLR-1 V2 build  (Read 3632 times)
Offline Robert Hornby
  • Terrigal NSW Australia
Re: AOG’s PMR BLR-1 V2 build
« Reply #30 on: March 19, 2019, 08:38:57 PM »
Tony, what surface preparation did you make on the boiler prior to the finish coat i.e. any etching or primer?
Robert
Offline AOG
« Reply #31 on: March 19, 2019, 10:32:02 PM »
Robert
I originally sprayed it with etch primer but I was concerned that it wouldn’t take the heat so I removed it and sprayed the barbecue paint directly on the boiler.
Tony
« Reply #32 on: March 20, 2019, 05:10:56 PM »
Thanks Tony, didn't know you could get high-heat paint in anything but flat.  Will have to browse amazon...
« Reply #33 on: March 20, 2019, 05:48:44 PM »
I have had very good results with this paint, a ceramic engine paint, up to 500F, no oven bake required to cure, goes on thin and dries quickly. Seems to take abrasion/handling quite well too, I have been using it on my steam engines and also RC boats. It comes it a bunch of colors, including semigloss black. Lots of auto parts stores carry it.
https://www.jegs.com/i/Duplicolor/318/DE1635/10002/-1
« Reply #34 on: March 21, 2019, 04:37:20 PM »
Thanks too, crueby, engine paint I've heard of, but bbq paint implies temps up over 500F.  Rustoleum Hi-Heat paint for instance, goes to 2000F.  And comes in gloss/clearcoat versions, which is news to me.  The high heat stuff does require a high temp. cure (600F).
https://www.amazon.com/Rust-Oleum-Automotive-260771-11-Ounce-Degrees/dp/B006ZLQ0JI/ref=pd_bxgy_60_3/133-0141963-4579607?_encoding=UTF8&pd_rd_i=B006ZLQ0JI&pd_rd_r=8cfd01ec-4bf6-11e9-a258-1dc4cbbc6958&pd_rd_w=ok5SU&pd_rd_wg=kpjHg&pf_rd_p=a2006322-0bc0-4db9-a08e-d168c18ce6f0&pf_rd_r=CZ5MHEFQ3RQQ5J6XTX5F&psc=1&refRID=CZ5MHEFQ3RQQ5J6XTX5F
Yuck, that is one huge link.
« Reply #35 on: March 21, 2019, 04:44:32 PM »
Thats he nice thing about the engine paint, if you dont need use above 500F anyway, it cures are room temperature, and I have found it goes on in a thinner film that is more durable. If you need the higher heat range, then the other types are needed.
Online gary.a.ayres
« Reply #36 on: April 01, 2019, 10:12:24 AM »
Great-looking boiler.
Congratulations!
