Author Topic: Removable crank for Sherline Rotary table  (Read 1805 times)
Online Vixen
Re: Removable crank for Sherline Rotary table
« Reply #15 on: January 01, 2019, 11:35:59 PM »
Green with Aciera envy ::) :disappointed: :disappointed:
« Reply #16 on: January 02, 2019, 01:01:41 AM »
Any time you want to pop over and use it Mike, you're welcome to.    8)
« Reply #17 on: January 02, 2019, 02:23:01 AM »
Dave,
That's an elegant solution, very creative. I'm not sure I would do well on your Aciera mill. To many variables, but then again an almost infinite way to set things up. good job
Offline Twizseven
« Reply #18 on: January 02, 2019, 01:45:30 PM »
Steamer,
You have some nice bits with your Aciera.  Mine is the earlier F12.  Gradually collecting bits.  My mate also has one (F1 version) and has made a number of castings for various parts.  Hew rebuilt the spindle is mine before I bought it of him..
Not got quite so many bits as yours.
Colin
« Reply #19 on: January 27, 2019, 01:55:02 AM »
OK   got to try out the Sherline rotary table with the Aciera mount and external crank.     It Worked Perfectly!
I dialed the table to zero, set the zero pointer and then mounted the table.   I then trammed the right most T slot to be parallel to the Long axis of the mill..   Easy peasy!
No zero setting dial required!
Nice rugged table.  It cut beautifully!
« Reply #20 on: January 27, 2019, 05:34:15 AM »
Glad it worked well for you Dave.  I've always loved my little 4" Sherline RT.  It's a joy to use.  And I'll be your custom handle made it even better!
