Author Topic: Removing damaged bolts/screws.  (Read 934 times)
Offline Gas_mantle
  • North Yorks - UK.
    • My Youtube channel
« on: December 23, 2018, 11:30:40 AM »
Hi all,
I'm trying to remove some screws from a boiler superheater in order to replace a gasket but they are stuck solid and have now partly snapped at the heads. Can anyone please offer any help?
I've tried heating them then using pliers but there isn't enough to hold on to, I'm not sure of the thread size but they are only perhaps about M3 and from what I can see stud extractors dont seem to go that small. I did wonder if it is worth trying to silver solder something onto the broken end to give something to grip.
Many thanks and a Happy Christmas to all  :cheers:
« Last Edit: December 23, 2018, 11:34:14 AM by Gas_mantle »
Offline simplyloco
  • Lots of Rebuilds in progress!
Re: Removing damaged bolts/screws.
« Reply #1 on: December 23, 2018, 11:42:04 AM »
If you look at this thread from 'Another Place' you will see how David and I (mainly 'I'!) drilled out and retapped six 8BA stud holes. Tricky, but eminently doable!
Good Luck
http://modeleng.proboards.com/thread/12050/990?page=4
Offline Gas_mantle
  • North Yorks - UK.
« Reply #2 on: December 23, 2018, 12:29:28 PM »
John, thanks for your reply,
I have now managed to remove them all, they did eventually come with heating and pliers after a cup of tea and a rethink  :)
The quality of these screws they must cost 10p a ton
Offline pgp001
  • West Yorkshire - UK
« Reply #3 on: December 23, 2018, 12:41:52 PM »
Peter
I would not put cheese head screws back in there.
Why not make some studs from good quality material, and hold the top down with nuts instead.
Phil
Offline Gas_mantle
  • North Yorks - UK.
« Reply #4 on: December 23, 2018, 01:18:53 PM »
Thanks Phil, that's what I'm doing cheeseheads screws can't be tightened down properly so I've put 5ba studs in.
When I finally got it apart there wasn't a gasket in  :facepalm2:
Offline Gas_mantle
  • North Yorks - UK.
« Reply #5 on: December 23, 2018, 02:06:14 PM »
The studs need a bit of tidying up but a quick steam test suggests all is well  :)
« Reply #6 on: December 23, 2018, 03:25:50 PM »
The smokebox is a very corrosive place  :paranoia: I hope you made those out of Stainless Peter.
Usus est optimum magister
Offline Gas_mantle
  • North Yorks - UK.
« Reply #7 on: December 23, 2018, 03:46:53 PM »
I haven't at the moment but thats a 2 minute job now I've rectified the leak, there's still a lot to do to fully rectify all the faults, the smoke box top is a terrible fit and isn't airtight. I need to anchor the steam take off to the boiler side as it's hanging in mid air at the moment.
Offline gary.a.ayres
« Reply #8 on: January 03, 2019, 10:57:26 PM »
Good to see you are beginning to progress with getting it up to scratch  :ThumbsUp:
Offline Gas_mantle
  • North Yorks - UK.
« Reply #9 on: January 03, 2019, 11:32:21 PM »
Thanks.
The steam take off on the right isn't anchored to the boiler body, I want to secure that next then have the steam take off exiting from the side. At the moment the top cap (smoke box) is a terrible fit and since the fittings pass through it cleaning the tubes means unscrewing the steam take off and safety valves to remove the cover. I think that is far from ideal and as I fire it on coal I need to remove the cover to clean the tubes after every second firing. Once I direct the fittings through the side I'll seal them properly and modify the top cap so it can be removed without disturbing the fittings.
