Author Topic: Restoring a Stuart Turner No. 9 Mill Engine  (Read 4520 times)
Offline simplyloco
  • Firstly the Stuart Beam, now it's the Big Time!
« on: December 21, 2018, 11:37:15 PM »
I've been away for a while, finishing my Britannia locomotive, but I was given an ancient Stuart Turner No.9 engine today, and I'm quite excited about restoring it! I'll do this in parallel with the build of a 4" Scotch boiler to power it, and perhaps also power the Beam Engine I built last year. I'm back on this site because the MECH site where the Brit resides is all about trains: I'm a model engineer, not a Station Master...
Here's how it looks, all seized up. Close examination showed it to be probably an 'Apprentice Piece', worked on by a few oiks - like me at that age!
Like a Curate's Egg, parts of it are excellent: the cylinder bore is a delight - other parts though, leave a lot to be desired! The crankshaft is bent, and the main bearings have never been line reamed so it is as tight as a drum. I've reamed the bearings, but a new crank is required.
WP_20181221_20_05_28_Pro by inkaboat, on Flickr
Watch this space. I want to bring it up to the standard in this video:
BTW here's the Brit needing just a few touches to finish it, but I've just been distracted by this engine!
WP_20181210_17_21_20_Pro by inkaboat, on Flickr
« Last Edit: December 21, 2018, 11:40:46 PM by simplyloco »
Re: Restoring a Stuart Turner No. 9 Mill Engine
« Reply #1 on: December 22, 2018, 12:53:46 AM »
Going to be a very nice Stuart engine, already is a beautiful loco!
« Reply #2 on: December 22, 2018, 02:35:48 AM »
Always loved the 9....I'll be watching along!
Don't be afraid to show some of that locomotive either!......Nice!
« Reply #3 on: December 22, 2018, 04:03:16 AM »
That has a pretty good knock in it! Persevere!
Peter
« Reply #4 on: December 22, 2018, 07:20:39 AM »
Wow! Love your Britannia! As others have said, please feel free to post some pics of your locomotive.  You've done a nice job on it!
I'll be watching your Stewart restoration too.
Offline Ian S C
« Reply #5 on: December 22, 2018, 11:28:47 AM »
Rebuilt one two or three years ago, I think the one I did started off worse than yours, but it came up good. Then the owner took the engine to a steam  weekend show, and it got nicked, which caused us to be a bit miffed.
Ian S C
ChuckKey
« Reply #6 on: December 22, 2018, 06:09:43 PM »
Not only does the example in the video knock, the crankshaft wobbles too.
Offline simplyloco
« Reply #7 on: December 22, 2018, 06:20:17 PM »
Onwards and Upwards!
I'll be fixing basics first, and making it look pretty later.
The first fault to address was the crankshaft. When the crank was turned, the small end of the connecting rod flailed about like  a Cheerleader's bits pompoms! There had been a pressing error therefore the crank pin was not perpendicular to the webs: one of the bores was 0.004" out of position. The absence of side thrust washers didn't help the situation either!
Today's job was a new crankshaft and thrust washers.
Machining the ends of the webs, utilising a simple stop on the vice jaws.
WP_20181222_12_02_13_Pro by inkaboat, on Flickr
Drilling and reaming the two 3/8" holes. There's a balancing piece on the end of the jaws, and I'm using slip gauges on the bed stop to achieve the 0.75" pitch. I can usually repeat holes to 0.0004" or less using this method.
WP_20181222_12_35_15_Pro by inkaboat, on Flickr
My new Eassom DRO is one thou out when compared to the slip gauge positioning... :headscratch:
WP_20181222_12_35_28_Pro by inkaboat, on Flickr
Making them look pretty!
WP_20181222_14_29_30_Pro by inkaboat, on Flickr
Certainly much prettier than the originals!
WP_20181222_15_36_46_Pro by inkaboat, on Flickr
Slip gauges for the gap, and a straight through crank which will be sawn off inside the webs. It's the only way... :LittleAngel:
WP_20181222_16_07_12_Pro by inkaboat, on Flickr
Crankshaft with new thrust washers. No more flailing about and it turns sweet as a nut!
WP_20181222_16_59_20_Pro by inkaboat, on Flickr
Slide valve is stiff, so that is the next job.
Merry Christmas everyone.
« Last Edit: December 22, 2018, 06:30:15 PM by simplyloco »
Offline Gas_mantle
  • North Yorks - UK.
    • My Youtube channel
« Reply #8 on: December 22, 2018, 06:56:06 PM »
Looking good John, it's amazing how a bit of simple machining can improve the look significantly.
I wondered if maybe the engine had been built by 2 separate people?  From what I can see the cylinder end of the engine looks to be of a better standard than the crankshaft end. The cylinder covers have more studs than the plan calls for so it kinda makes me think the builder wanted to make a good job of it and create an authentic look. I could wrong but the amateurish crank webs and oil cups etc give me the impression they were built by someone less experienced.
Offline simplyloco
« Reply #9 on: December 22, 2018, 07:02:33 PM »
It's definitely an 'Apprentice Piece', judging from the varying build standard! The cylinder is a delight, the rest is gruesome...
Offline simplyloco
« Reply #10 on: December 23, 2018, 06:27:49 PM »
Well, it leaks like a sieve - it's held together with CSK 5BA screws as I have to get some decent studding-  and the flywheel wobbles, but it works and it doesn't knock! Just click on the pic to get you into flickr, and watch 33 seconds of satisfying model engineering! Please forgive my shaky handwriting and the noisy compressor.
I now have to make it look pretty...
WP_20181223_18_06_15_Pro by inkaboat, on Flickr
« Reply #11 on: December 23, 2018, 07:33:27 PM »
Very nice! The new parts did the trick.    :ThumbsUp:
Offline simplyloco
« Reply #12 on: December 26, 2018, 06:55:50 PM »
Amazing what a bit of emery cloth and oil can do to a very old and scabby cast iron flywheel!
The Gin helps the concentration as it took about an hour...
DSC00657 by inkaboat, on Flickr
« Reply #13 on: December 26, 2018, 07:32:21 PM »
 :thinking: It didn't need much gin to get that finish John. Or was that just enticement to encourage you to get it done  ;)
Offline Gas_mantle
  • North Yorks - UK.
« Reply #14 on: December 26, 2018, 07:43:09 PM »
If you drink enough gin the wheel will look fine without polishing - infact both of them will  ;)
