Author Topic: Lehmann Stirling Engine  (Read 10559 times)
Offline PJPickard
Re: Lehmann Stirling Engine
« Reply #45 on: June 19, 2019, 11:04:45 AM »
Excellent work, I will remember that when I make mine! Thanks!
« Reply #46 on: July 11, 2019, 06:27:44 PM »
Still following along in the background  :ThumbsUp:  :ThumbsUp:  :wine1: Milling the levers from  solid was an interesting and successful solution  :praise2:
Offline yogi
  • Duncannon, PA USA
    • Yogi's Workshop
« Reply #47 on: October 03, 2019, 09:04:16 PM »
Thank you guys for the kind comments. It's very much appreciated.  :cheers:
To continue the work on the lever assemblies, I'll be machining the forks.
The first side is milled out.
The fork is then turned over, and the second side is finished.
To finish the fork with the radius at the top and the holes, I used a set (of well used) soft jaws.
The finished fork:
Thanks for following along, and stay tuned for more.
Yogi
toolznthings
« Reply #48 on: October 04, 2019, 01:10:24 AM »
Very nice !  :ThumbsUp:
Offline PJPickard
« Reply #49 on: October 04, 2019, 01:23:40 AM »
Good to see this still going...I will make one. Someday!
Offline yogi
  • Duncannon, PA USA
    • Yogi's Workshop
« Reply #50 on: October 07, 2019, 09:24:09 PM »
Thanks guys!  :cheers:
The forks for the second lever assembly are made in a similar way as the first.
Milling the first side.
As usual, the second side is finished up in a set of soft jaws.
The two finished forks:
To silver solder the parts together, I carefully located and clamped the pieces to prevent any movement while heating the parts.
..and the two finished lever assemblies:
Yogi
toolznthings
« Reply #51 on: October 08, 2019, 12:59:23 AM »
Following along, nice work for sure !!  :cartwheel:
« Reply #52 on: October 08, 2019, 01:03:28 AM »
Very nice work Yogi!
Great to see more progress on the Lehmann.
