Author Topic: building the Frisco Standard Model  (Read 33659 times)
« Reply #135 on: February 21, 2019, 02:26:05 PM »
Either piston will work. The piston has rings on it, so the piston can be made .001 to.002" undersized to account for differential heat expansion between the aluminum piston and cast iron sleeve.
« Reply #136 on: February 22, 2019, 10:41:45 PM »
Pete, Roger, Brian; thanks for your comments and input.  Thanks for those silently following along also.
I decided to make the pistons out of aluminum.  I have the stock and this way I don’t need to silver solder them together (have I mentioned that I ABHOR silver soldering.. basically because I can’t do it well?).
Any hoo, here I am, gleefully turning a blank of aluminum to the OD of the piston.
Cutting the ring groves.  I have a friend who was walking with me around the Cabin Fever Expo a few years ago.  He’s a great modeler, so when he talks I tend to listen.  As we were walking by the Arthur Warner booth he pointed out a set of slitting tools and said “You need those”.  At the time I couldn’t really see a use for them but I’ve learned to listen.  He was right they REALLY do come in handy from time to time, like for cutting these piston ring groves.
Now with the piece parted from the stock and turned around in the lathe, I’m facing the piston to the correct length.
In this photo I’m forming the skirt.
Time to move to the mill and drill and ream the hole for the wrist pin
I’m hoping I will wrap up these pistons tomorrow.
« Last Edit: October 17, 2022, 08:19:33 PM by Craig DeShong »
« Reply #137 on: February 22, 2019, 11:53:41 PM »
Looks Awesome Craig!
« Reply #138 on: February 23, 2019, 09:44:49 PM »
Thanks for the comment Dave.
<a href="https://www.youtube.com/watch?v=qFALsmERyxU" target="_blank">http://www.youtube.com/watch?v=qFALsmERyxU</a>
Got the connecting rods, rings, and pistons installed.  Everything goes up and down and round and round as it should.   :whoohoo:
« Reply #139 on: February 23, 2019, 10:17:24 PM »
Hello Craig,
Looking beautiful and it is coming along quite well. Great to see all the parts together and in motion on your video.
« Reply #140 on: February 23, 2019, 11:31:28 PM »
Nice!  :ThumbsUp:
« Reply #141 on: February 24, 2019, 04:14:27 AM »
Craig,
Looks great, everything goes round and round and up and down. :DrinkPint: I'll drink to that.
« Reply #142 on: February 25, 2019, 11:31:41 PM »
Thomas, Pete, Art; thanks for your comments.  Thanks also for those silently following along.
I started working on the heads today.  These are irregular shaped castings with no really good way to hold them.  I decided to file some flats to give me some purchase on the casting and then milled a flat surface on the bottom (that mates the top of the cylinders).  Once this was attained I outside bored the cylinder protrusion.  I would have preferred to do this on the lathe, however I couldn’t really figure out how to hold the casting and align it properly.  On the mill I could run my indicator back and forth and get a reasonable alignment of this irregular surface.
The two heads are mirror images of each other; here’s the same operation on the other head.
With a flat surface to align the casting, I scribed a line through the center of the cylinder bore and in a straight line with the front-back orientation of the casting.  This allowed me to mill the flat for the intake but more importantly, one of the two datum references for all the future measurements for machining this casting.
With the two datum references established I could locate the cylinder center from the top of the casting.   This allows me to locate and drill the head mount bolt holes.  The drawings indicate these should be drilled at the center of boss.  I wanted to verify that these holes wouldn’t pierce the cylinder liner.  I decided I wanted each hole center should be at least .950 inches from the cylinder centerline.  This allowed the cylinder bolt to be located well within the aluminum casting so it would not interfere with the cylinder liner.  I did have to offset a few bolt holes away from center of casting to achieve this.
With the heads drilled for the head bolts, I affixed them to the cylinder casting and spotted the bolt hole locations.
With the bolt hole locations spotted I could drill and thread the cylinder for the head bolts.
« Last Edit: October 17, 2022, 08:29:08 PM by Craig DeShong »
« Reply #143 on: February 26, 2019, 12:27:37 AM »
Looks good so far Craig, hopefully the rest of the machine work on the heads goes ok for you.
« Reply #144 on: February 26, 2019, 12:33:39 AM »
I was afraid to ask when you posted the up and down and round and round vid.   But the heads DO reach down inside.   pwew!    8)
« Reply #145 on: February 26, 2019, 01:02:41 AM »
Craig, I have never outside bored like that, does it require a cutter with edge on other side, or running the mill backwards?
« Reply #146 on: February 26, 2019, 08:17:56 AM »
 :thinking:
Positioning those heads bolt holes looked to be a tricky job to balance things out I bet you are pleased it worked ok  :).
« Reply #147 on: February 26, 2019, 11:00:13 PM »
Chris- just ran the mill backwards (and set the down feed to up-feed since the mill was running backwards).
Jo- got to drag out the old Trigonometry and use the Pythagorean Theorem.  I could read the x & y from my DRO and by applying the theorem, as long as I got a hypotenuse of the triangle over .95 inches I knew I was good to go.  As George B. in a post not long ago said “The math doesn’t lie”.
Today I started out locating the hole in each head for the vertical cam shaft.  The building notes instruct the builder to make a pointed shaft (slightly longer than the allowed space) and fit it to the base, then attach the head and “spot” the location for the hole.  I’m doing this in the photo below.
Once the location of the hole was spotted I took measurements on the mill from the two X and Y datum, turned the head over and then re-located the location for the bearing hole.  I then center drilled, drilled and finally reamed the hole.  The drawings call for this steel camshaft to run in the aluminum casting.  I’m again choosing to use a brass bushing so I over bored the hole in preparation for installing the bushing.
An assembly check shows both upper camshaft bearing holes to be located correctly.  WHEW!
There were a plethora of holes to be drilled thru the top of both castings.  Things went pretty well with the front casting, not so well with the rear casting.
With the rear casting, the holes just didn’t seem to locate on the established bosses well, and the two furthest outboard holes were completely off the casting!  I was thinking at first that I was working with another measurement in error, but the same measurements are used for both castings and the castings are supposed to be mirrors of each other.  Had I shifted the casting outboard more, the head bolts would not have hit their bosses.
I just decided to re-locate the holes for the exhaust valve pivot and the igniter pivot as seen in the drawing below.  This may (will?) require me to do a slight re-design of the rocker and pivot arms, but that probably can be accomplished later.
« Last Edit: October 17, 2022, 08:34:16 PM by Craig DeShong »
« Reply #148 on: February 27, 2019, 10:15:37 PM »
Work progressed on the heads today.  It was a busy day and I missed taking “in progress” pictures.  I guess I was too busy concentrating on all the steps.
The clearances between some of the holes is tight and I was concerned I might get some interference, especially since I didn’t hold exactly to the drawings in my work yesterday.  Turns out I have only one minor interference in one of the heads; It’s with one of the valve guides and I believe once I install the guides I can touch-up the hole and everything will be ok.  The interference isn’t enough to reach the valve stem.
I’ve included a few photos of the completed heads, sans the holes through to the valve guides which I’ll need to drill after I fabricate and install the guides.
« Reply #149 on: February 27, 2019, 11:06:05 PM »
Nicely Done Craig!    Very Unusual heads!  The slot is interesting...
