Author Topic: Coax Indicator, designed by W.K.Todd  (Read 2633 times)
« on: December 12, 2018, 11:05:45 AM »
Hi everybody,
I am trying to make one, here the slightly modified design and were I am today.
Offline BillTodd
    • Bill's website
Re: Coax Indicator, designed by W.K.Todd
« Reply #1 on: December 12, 2018, 12:19:30 PM »
Looks good,
 It's really a buzz to see someone making something I designed  :pinkelephant:
Were the drawing ok, were you able to follow my description?
P.s the pdf is on my google drive here:
https://drive.google.com/file/d/0BwXDcXKx2KzlaUVrZ0l6QU4yaTA/view?usp=drivesdk
« Last Edit: December 12, 2018, 12:22:33 PM by BillTodd »
wy omnibus Latinis taurus stercore?
« Reply #2 on: December 12, 2018, 01:44:04 PM »
Hi Bill,
thanks for the link to your drawings.
It seems that I have downloaded the same set some time ago, I think via MadModder.
During the last summer I have redrawn everything in Fusion 360 and I have started the making now.
For me the information of the real shape and dimension of the rocker was a bit weak, so I have imported the picture into Fusion and the software has calculated everything by given the dimension of a known whole, 4 mm.
Progress will be shown here.
« Reply #3 on: December 12, 2018, 02:36:54 PM »
... and the up date from this afternoon.
The two aluminum parts are fitted togther with some epoxy glue and cured in the oven at 100C.
My fingers should give an idea about the overall dimension.
Currently I am playing a bit with Fusion CAM.
Online Vixen
« Reply #4 on: December 12, 2018, 03:52:18 PM »
Hi Bill and Achim,
This coaxial indicator looks very useful and has been added to my 'to do' list   :ThumbsUp: :ThumbsUp:
Do you find it more convenient to have the dial facing forward of facing upward? I am thinking about the view of the dial, when you swing it through 360 degrees.
Online sco
« Reply #5 on: December 12, 2018, 04:46:10 PM »
I've always wanted one of these so have added it to my 'To Do List' too!
Thanks Bill and Achim,
Simon.
Ars longa, vita brevis.
« Reply #6 on: December 12, 2018, 04:55:34 PM »
Hi Bill and Achim,
Hi Mike, with the M4 bolt a clamping in every position should be possible.
« Reply #7 on: December 12, 2018, 05:08:45 PM »
Well the beauty of a coax indicator is that the dial stays in one place and doesn't swing through 360 degrees.
Online Vixen
« Reply #8 on: December 12, 2018, 05:13:00 PM »
Thanks Bill,
I had assumed you rotated the dial gauge, but it seems you can also rotate the spindle and the dial remains stationary.
Mike :facepalm: :facepalm:
« Reply #9 on: December 12, 2018, 06:19:06 PM »
I had to do a search on coax indicators, there are a couple of youtube vids that show them in action - pretty slick units.
Offline BillTodd
    • Bill's website
« Reply #10 on: December 12, 2018, 06:22:52 PM »
Hi Bill,
Ok, perhaps i should have made it clear that the shape is unimportant  , except for the offset stylus mount, which reduces the overal height.
I was going to experiment with the shape of the sliding feet , so as to reduce sine error .
« Reply #11 on: December 12, 2018, 09:46:36 PM »
Chris that are great for things like aligning the RT to the mill spindle. The only downside is they require a lot of headroom, but perfect for Bridgeport type mills.
« Reply #12 on: December 12, 2018, 10:19:32 PM »
Having the taller column ony sherline, could work...   Hmmm...
« Reply #13 on: December 12, 2018, 10:30:19 PM »
Bill's design looks like it needs less headroom than my SPI unit. So yeah it could work with the taller column.
Offline BillTodd
    • Bill's website
« Reply #14 on: December 12, 2018, 11:30:22 PM »
I designed it to be as short as possible because the  vertical head on my Haighton mill has very little head room .
